Monster Powerbar 1100 ???
mufsoman
mufsoman Posts: 640
I'm currently using a Monster Powerbar 1100 with my HT set up that I bought quite some time ago. Judging by the comments on this forum, Monster doesn't seem to have a very good reputation. I'm assuming an APC H10 or H15 or Panamax 5100 will provide more protection, but will there any difference in video or audio quality? Is it worth the money to upgrade? Thanks
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
Atmos: Polk OWM3 x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • kawizx9r
    kawizx9r Posts: 5,150
    edited November 2009
    I personally owned a Panamax 5100 Max and loved it. Cleared up a ground loop issue I had, kept my components safe and it cleaned up some 'hiss' noise I was experiencing on my digital cable. Ran the coaxial from the wall to the p.conditioner, then out to the digital cable box and tuned to channels that had background static/hiss and sure enough it was all gone.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    I use an avs2000 & hts5100 tandem and think it's great! Really cleaned thing's up for me seeing as i live in a building....
    I purchased both unit's used at a great price and one (hts5100) ended up being faulty :( I sent an email to Monster asking how/where to go about fixing it and they sent me out a BRAND NEW in box replacement! TOTALLY free, no shipping cost's! Nothing! Now that is CUSTOMER SERVICE ;)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • anhchungdoan
    anhchungdoan Posts: 760
    The good people @ Vann's have the APC H10 in black for $174.00 including shipping. That's all you need, brother.
    Some of the Surge/ line conditioner will change the SQ of your system either way ( better or worse depedning on your taste). The APC H10 won't change nada to the SQ of my gear that's what I want.
  • anhchungdoan
    Some of the Surge/ line conditioner will change the SQ of your system either way ( better or worse depending on your taste). The APC H10 won't change nada to the SQ of my gear that's what I want.
  • mufsoman
    mufsoman Posts: 640
    So is it worth it to upgrade from the Powerbar 1100 to something else or is the Powerbar doing a similar job as the APC, Panamax, etc???
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • concealer404
    concealer404 Posts: 7,440
    The H10 does actually affect the sound.... But it's certainly not in a bad way. It filtered out a bunch of noise in my case.
    You can usually find it for $100 if you keep an eye on sales. Otherwise, the Vann's price isn't too bad. I paid $90-something for mine.
    The powerbar... i'm not real familiar with. If you're happy with it, keep it. I think it's just a surge protector, right? Or does it condition as well?
