LSi9 or LSi15
  • NewHTguy
    NewHTguy Posts: 584
    edited November 2009
    Face wrote: »
    LSi9's dip to 2ohms, the LSi15's only dip to 3ohms.
    Are you sure of that?
    http://www.polkaudio.com/forums/showpost.php?p=828876&postcount=9
    Anyway, are you saying that that Lsi 9's are more difficult to drive overall?
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • Face
    Face Posts: 14,340
    Yep, I measured them both a few months ago.
  • Hilbert
    Hilbert Posts: 316
    I wonder if the guys who recommend 9s over 15s would mind giving a reason? (Or several.)
    I ask because I have 9s and am constantly tempted to pluck a couple of 15s off the Polk Direct site. I'd like to be talked out of this for the obviou$ rea$on$.
    treitz3 Posts: 19,986
    To me, the 9's represent a more accurate representation of the spectrum. They image better and do not exhibit the slowness, boom or muddiness that the LSi15 does. It's just a more musical speaker IMO.
  • Hilbert
    Hilbert Posts: 316
    Ah, thank you---just what I was hoping for.
    My 9s are just a bit boomy at times; I thought 15s might be an improvement.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    tonyb Posts: 33,072
    Hilbert wrote: »
    Boomy eh....what are you driving them with ? How are they set up ? What kind of cables are you useing ? What's the other gear ? Do you use a sub ? Whats the crossover set at ?
    If your having a problem getting good sound out of the 9's,just say so and maybe we can help you tweek them a bit.
  • jimmydep
    jimmydep Posts: 1,305
    treitz3 wrote: »
    I haven't noticed any "Boominess" (is that a word) with the LSi-15's, I have found that speaker placement can be a little tricky, especially in a less than perfect room, which may have to do with the side fireing woofer.
    When listening to the 15's in two channel, I don't use a sub, and the low end is accurate and clean.
    I found the imaging on the 15's to be quite good although small changes in speaker placement (distance from walls, toe-in, or toe-out) can significantly change the soundstage and imaging.............so if you like to tinker....
    I listen to many genre's of music, but feel the Lsi's sound best with, female pop, country, and jazz.....worst with, that screaming type of hardcore noise my son listens to.
    Hope this helps.
    Jimmy
  • Hilbert
    Hilbert Posts: 316
    tonyb wrote: »
    Thanks for offer to assist.
    The 9s sound great about 99% of the time. Boominess happens on only a handful of CDs, mostly string quartets, mostly recorded in the 80s, so maybe they weren't well recorded to begin with. Boominess more pronounced on playback via Oppo 83 than on Cambridge 640C. The other gear is Emo xpa-5 (contemplating upgrade to Wyred 4 Sound ST 500) and USP-1. HP Crossover set at 60 hz; LP at 80 (with caveat the USP-1 affords only very approximate control over these settings). The speakers are at right angles to the wall, 6.5 feet apart and a foot away. I experimented and found right angle offered best imaging.
    Cables are all from Blue Jeans; I intend to invest in Signal cable bi wire at some point.
    I shall be interested in any and all suggestions for improvement, but I repeat the boominess is really pretty minor.
  • Bernal
    Bernal Posts: 991
    For music? the Polk LSi15.:)
    My settings to use bi-wiring: HF "Oxygen-free copper / Oxygen-free high thermal conductivity"
