spades,bananas, or ? whats your preference?
cstmar01
cstmar01 Posts: 4,424
edited January 2010 in Speakers
Just curious as to what people on the forum like in terms of connections. I'm currently using bananas but picked up some MIT cables that the ends can be switched out so curious as to if people feel spades are a better connection.
Post edited by cstmar01 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited November 2009
    Sup Chris!
    Banana's for easy connect/disconnect.
    Do your MITs have the iconn connect termination? Otherwise I've got a whole set of bananas and spades left over in my box of stuff.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • ben62670
    ben62670 Posts: 15,969
    Nanners. They can't come loose and short like spades can.
    Ben
  • packetjones
    packetjones Posts: 1,059
    I like the nanners myself. I find them the easiest to use. To each their own though.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • danz1906
    danz1906 Posts: 5,144
    Banana's on the Speaker end,Spades on the amp end.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • hearingimpared
    hearingimpared Posts: 21,136
    I have bananas on my MITs.
  • cstmar01
    They do have the iconn ends. I was tempted to pick up some spades to try them out seeing I've only been using bananas, but didn't feel like paying the extra money for them if I would end up not even using them.
  • leroyjr1
    leroyjr1 Posts: 8,785
    I have bananas and spades but prefer all bananas.
  • Ern Dog
    Ern Dog Posts: 2,237
    I like bananas for a quick and secure solution.
    Tony M Posts: 11,578
    bananas.. but I think you get what you pay for. The cheap ones have cheap banana ends.I know that.
    I've read the locking ones are the best to use
  • jimmydep
    jimmydep Posts: 1,305
    I like nanners, it makes swapping stuff out quick and easy.
  • beardog03
    beardog03 Posts: 5,550
    I have nanners on the amp end and spades on the speaker end
    sometimes it works best if you have spades on the speaker end, and nanners on the jumper wires for the top and bottom posts
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • concealer404
    concealer404 Posts: 7,440
    Nanners!
  • sir_lagzalot
    sir_lagzalot Posts: 258
    I've tried both but prefer nanners.
    ****Home Theater****
    Integra DHC-40.1
    Rotel RMB-1075
    Fronts 265-RT
    Center 265-RT
    Rears 65-RT
    Sub BIC H-100
    ****VIDEO****
    Projector Epson 8700 UB
    BLU-RAY Sony BDP-S1000ES
    ****2-Channel****
    Magnepan SMGa
    Sub ED A3-250
    AMC 3100a
    TT Music Hall 2.2
    Bellari VP 130 Phono Pre
    Grant Fidelity Tube DAC-09
    Sirius Stiletto 2
  • vc69
    vc69 Posts: 2,500
    danz1906 wrote: »
    Same here.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • kawizx9r
    cstmar01 wrote: »
    Well, I don't have a full set extra but I have 2 spades alone (iconn ends) if you want'em just to try next time you come by. I use mainly banana, but spade-end on my maggie mates since I ran out of'em!
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • gtu2004
    gtu2004 Posts: 620
    anyone care to explain what nanners are? how do they look like?
    Edit:
    nvm, banana plugs...I know they are convenient and all, but I use bare wires...swapping out speakers are a pain, but I think bare wires are the best...
    Onkyo 805, RtiA5s, Csi5, Rti6s
  • TouchOfEvil
    TouchOfEvil Posts: 967
    I like nanners but honestly prefer nudes.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • cstmar01
    kawizx9r wrote: »
    Ok, I'm just tempted to try them out to see if I like them over the bananas. I do like my MIT cables, the only problem I have right now is my stupid mono blocks have the connections about 12 inches apart soo the cable doesn't split far enough to to use on the amp end and I don't feel like pulling them apart and redoing it as I just got them, oh well, I'm just going to use them for the center for now, love them though, think I'll be picking some more up soon!
  • skrol
    skrol Posts: 3,437
    I recently went bananas. Here is the thread that compares some popular bananas sold on EB.
    http://www.polkaudio.com/forums/showthread.php?t=82272
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • comfortablycurt
    comfortablycurt Posts: 6,745
    gtu2004 wrote: »
    Edit:
    Bare wire has a lot of disadvantages. Copper wire oxidizes over time when it's exposed to oxygen, which will degrade the signal over time.
    With a properly terminated cable, the copper wire will be sealed off, so no oxygen will be coming directly in contact with it.
    Personally, I use bananas all around. I've never tried spades.
    Nanners make speaker swapping a piece of cake.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • woodsman10b
    woodsman10b Posts: 408
    Curt do you have any idea how long it takes copper to oxidize, in an indoor invironment with low moisture levels it would take nearly 10 yrs. Now if it were in a garage with lots of temp changes and higher moisture levels it could be less than a year.
    I use bananas
    Most of them only hear how loud it sounds, and the rest of us hear everything else - :rolleyes:
  • ben62670
    BTW chiquita banana's are much better than Dole's. I am not sure if it is the type of banana, or what, but they are smoother and sweeter than the dole's.
    http://www.youtube.com/watch?v=RFDOI24RRAE
    Ben
  • skrol
    skrol Posts: 3,437
    Which ever brand, look for organic. I know studies say that you don't have to worry about it with bananas but I think the additives and genetic modification takes away from the natural properties and can be down right dangerous in the long term-inal.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • ben62670
    Man I am going organic as possible. The price is prohibitive sometimes, but that just means I need to grow more. I have way too many health issues to not go all natural. I have my two little sweethearts 4 and 6. I am getting the 6 YO to eat what we grow. It is an awesome bonding time, and she gains interests in veggies we grow. My girls are so sweet it is unbelievable :)
    BTW hormone free milk and antibiotic free chicken;)
    Ben
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    Low mass, solder type banana's....
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • comfortablycurt
    I use bananas
    So, you're saying that replacing your wire every 10 years is better than simply terminating them properly and never having to replace them again?
    When I got the GLS nanners for my 2 channel rig, I A/B'd them with bare wire. I had a pair of speaker cables that were bare, and a pair of the exact same cable terminated in the nanners. I heard absolutely no difference.
    I think bare wire has enough disadvantages to more than negate the theoretical minute loss of signal quality that you get from the termination.
    Also, bare wire has the chance of getting loose strands crossed. This can cause damage to speakers and amps...with terminations this is much less likely.
  • woodsman10b
    Yes I agree 100% with these other points Curt, it was just the one point that you gave wasn't a very strong one thats all:D jus me bein a dousche:eek::D
  • gelinas
    gelinas Posts: 226
    I use banana plugs. They are easy to use and make plugging/un-plugging easy.
    Plus I like they way they look
  • cstmar01
    ben62670 wrote: »
    Its kinda funny though for me here in WI our organic bananas acutally cost less than regular bananas at this one store I go to. I just wish my apartment would let me grow stuff outside as then I would do my own but for now I just gotta settle for our co-op.
  • ben62670
    Tin your bare wire with silver solder if you want to use straight wire. Silver conducts better than copper when exposed to the elements. Also there are no stray strands to short your amp.
    Ben
