Weird Issue...
  • woodsman10b
    woodsman10b Posts: 408
    edited November 2009
    Well, it doesn't help that the two times I've had issues, the songs were poorly compressed MP3's. :o That and they have many instruments playing at the same time at loud levels... But I didn't really think about the dips either. That's a good point. I'm not saying my Onkyo is perfect or anything but I was just thinking that it can't only be my receiver causing the tweeters to trip.
    Dont use poor quality mp3 recordings, they will harm anything you play loud through. I only use 320 bitrate and nothing less on my systems, and even at that I usually only use original recordings when cranking it up a bit.
    Most of them only hear how loud it sounds, and the rest of us hear everything else - :rolleyes:
  • Driver_King
    Driver_King Posts: 266
    That is a terrible combination of problems I've got there. Craving for loud music, heavy-metal songs, certain songs recorded poorly, low-bitrate MP3's, possibly underpowering the speakers, 4ohms and lower, old Polyswitches...:eek:;):D By the way, I usually don't listen to low quality MP3's (they are truly garbage) but some songs I can't help. I guess I should look for a better quality version of them next time. ;)
    Home Theater:
    Onkyo TX-SR805
    Behringer EP2500 for SDA's
    Polk SDA II fronts
    Polk Monitor 5Jr. surrounds
    Polk Monitor 4 back surrounds
    DIY A7-900 and DIY A3-300
    F1nut Posts: 52,001
    Here's a link to the replacements you need if you are 100% positive that you own SDA 2's. If they are a different model, such as the SDA SRS 2, then you need a different model polyswitch.
    http://www.mouser.com/Tyco-Electronics-Raychem/Circuit-Protection/PTC-Resettable-Fuses/_/N-5g3eZ1z1411n?Keyword=RXEF030&FS=True
    I would strongly suggest that you replace them and not bypass them given the info you've provided.
  • Driver_King
    Yes, I own the SDA II's (with three drivers and two SL1000 tweeters).
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
  • gdb
    gdb Posts: 6,012
    I'm planning to go "Old School" by replacing my polyswitches with fast blow fuses in the appropriate amperages. You could go that route too if you wanted to.;) Good Luck !
  • superjunior
    superjunior Posts: 1,632
    how do you access the polys on 2b's? I'm having the same issue
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • Face
    Face Posts: 14,340
    They're on the crossover.
  • superjunior
    Face wrote: »
    cool, thanks Face
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • Driver_King
    Today, I replaced the Polyswitches that were sent to my by Polk.:) Results? :eek:
    To say there was a nice improvement is a complete understatement. After replacing the Polyswitches in my right speaker, I turned on my receiver to see what sort of difference was made and noticed the speaker was noticeably louder and sounded rejuvenated. After listening to some music, I came to the conclusion that the speakers have never sounded this good. It is like I have new speakers. I checked my SPL meter after playing some pink noise to see what sort of dB increase there was. I was measuring 78dB when I had the speakers calibrated to 75dB a few weeks ago. I know I'm not mistaking the difference in sound level for quality however. I have not even come close to loud yet since it is late at night but the difference in high frequency detail and natural sound of voices and instruments is mind-blowing. I can't believe the Poly-switches made THAT much of a difference. I urge anybody who has Poly-switches in their speakers who hasn't had them replaced to contact Polk and GET ON IT. Nothing beats a tweak like this...especially when it is FREE!
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
    F1nut Posts: 52,001
    Don't get too excited. New from Mouser they are only $0.34.
  • Driver_King
    No, I know. My point was that of all of the tweaks I've made so far, nothing beats the improvement of this tweak that costs so little, free in my case.:D The improvement may not be as drastic for anyone else. I had my Polyswitches trip a few times and they were attenuated because of it. That makes a good difference in sound.
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
  • dbnh
    dbnh Posts: 194
    I think Onkyo gear has its place and can perform well when paired synergistically. That being said, I find that Polk SDA speakers demand high current amps, and I question whether Onkyo gear can provide feed that high current.
    Glad the polyswitch thing worked.
  • Driver_King
    Oh no doubt. I know it can't sustain those power ratings, especially when other speakers are on. You can tell when it runs out of juice (for me, it's around 100dB). I am looking forward to leaving the rest of my speakers to the Onkyo so I can have my SDA's separately powered.:cool:
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
