Room treatments
ROTFLMAOI use the piles of dirty laundry in my office !!
works well until wash day !!
Use some air wick and just buy new clothes, case closed
Same here, your post is very beneficial, I've been dragging on room threathment looking for economical but efficient way to do so without falling in the expensive marketting trap.I am glad you posted this thread...
I will revisit it once i get my office / 2ch room back to where it is supposed to be
treatments make a huge difference......and you all have given me some useful ideas
Thanks !!
Cheers!
TKDARE TO SOAR:
If your room corners are available for treatment that is a prime location for dealing with low frequency room modes.Custom building some triangular corner traps (ala Super chunks) and placing them directly in the corners should prove benificial.
Size matters so the greater the thickness and width of the absortion material(fiberglass or mineral wool)the greater effectiveness it will have at lower frequencies.I built these easily and cheaply for use in the corners of my room. http://www.polkaudio.com/forums/showthread.php?t=84121&highlight=corner+trapsTesting
Testing
Testing -
Cheers!
TK
Room treatments are the best bang for the buck out there."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Great GV thanks! This is just what I've needed, most of what I look at looks so hugly and disguise/ruined a room good looks/design. This will look much better than most designs I've seen so far :cool: Which is best, fiberglass or mineral?If your room corners are available for treatment that is a prime location for dealing with low frequency room modes.Custom building some triangular corner traps (ala Super chunks) and placing them directly in the corners should prove benificial.
Fully agreed however, what is typically offered on the market is often overpriced and home made (when you know what you are doing evidently) is more rewarding, least expensive and that always satifies the cheap old brick that I am
. By the way, soundproofing is even worse at gouging but is also mandatory in many cases so, if one has low priced but efficient DIY idea I'll gladly take the advices too
Cheers!
TKDARE TO SOAR:
Living room:
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro -
I've noticed he used peg board instead of plywood, I wonder what the benefit would be (if any)?DARE TO SOAR:
concealer404 wrote: »Disregard that, i'm dumb. Forgot that the 703/705 was rigid.
So i could in theory just cover it and put it up on the wall without building a frame. Not ideal, i know, but building a frame is out of the question for the moment.
I think i'll give that a shot later this month. Bonus check wooo!!
Mine are made with OC 703. There two inches thick and with a four inch frame spaces the Insulation another two inches from the wall which aides in absorbing high frequency's..
Your more than welcome to come down and pick mine up if you want to play with them before you spend any more money... I hate to say it. But you might find that your room might not be taimable... Thats a crazy **** room you've got..
Nik -
nikolas812 wrote: »Mine are made with OC 703. There two inches thick and with a four inch frame spaces the Insulation another two inches from the wall which aides in absorbing high frequency's..
Nik
We'll see.... but you're going to need them when you get these Monitor 7s outta here.
Either one will do the job nicely but OC703/705 being rigid will be easier to work with when cutting the triangular pieces.However being as you are in Canada you may by default have to use mineral wool as it might be difficult or impossible to find the OC product.I used the ROXUL brand mineral wool which is readily available and inexpensive.I'll reinterate that the more damping material you can get into the corners the greater the benifits at low frequencies.Which is best, fiberglass or mineral?Testing
Testing
Testing -
The holes in the peg board will allow some sound to pass through so if there is an air space between the panel and wall as shown in the link,it will increase the absortion at lower frequencies some.I've noticed he used peg board instead of plywood, I wonder what the benefit would be (if any)?
I built similar panels to those in the link for my first reflection points but left most of the back open,only a narrow strip of peg board was used on either side to keep the mineral wool in place.Unlike the corner traps using only 2" thickness of absorbtion material is sufficient for panels at the first reflection points.Testing
Testing
Testing
