cc and the infamous upgrade plan
Airplay355
Airplay355 Posts: 4,298
edited September 2003 in Speakers
well guys i did it AGAIN. i took back my rti150s two months after getting them and traded them for rti70's, a csi40 and fxi30s. apparently the rti70s and csi40 arent on clearance here yet so i had to pay full price for them ($399 each for rti70s and $399 for the csi40) the fxi30s however were $71 each. the total for all of this was $156 over what i paid ($1269) for the rti150s. there was also 100ft of monster cable included in there. i have now completed a surround sound setup in my room, theres only one problem now. my left surround isnt working, and i have ruled pretty much everything out except my receiver. since i bought my receiver *refurbished* im guessing that a problem with the left surround only might be a characteristic of that. it was purchased from accessories4less so i have a 1 year warranty, i just need to find a service center around here, unless my stupid receiver is just being dumb and decides to fix itself. it was working last night, and i definetely didnt blow my speaker, because i switched the left speaker to the right and it worked fine, its not the wire cuz i switched the right strand to the left. neway its gotta be my receiver, any ideas or suggestions? im thinking that i just have to take it in to get it cheakced out...its free neway so who cares.
neway, like my new setup? nicer then rti150s and a cs245i huh? heehee:D
Post edited by Airplay355 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    I'm glad you are happy bro, but sounds like you got rooked on the 70's and 40 - they ARE on clearance EVERYWHERE else.
    Time to talk to the store manager.... Only caveat is, you'll have to buy more gear to meet the upgrade clause. (which isn't a bad thing)
    Cheers,
    Rooster
  • KeithV
    KeithV Posts: 107
    So, they weren't on clearence at that store? Thats weird... it's set by corporate. If they are an out of program item the price should end in .95 or .96, and that should apply to every store in the country.
  • Loud & Clear
    Loud & Clear Posts: 1,538
    Nice manuevering. What are your plans for a sub?
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • jkratzer
    jkratzer Posts: 148
    Good going. Your new setup is just like mine and it rocks. The RTi150's I hear need alot of power to sound their best otherwise you are better off with the RTi70's.
    It seems that some CC stores price their speakers lower than others. The store managers must have the ability to set prices. I found that the FXi30's were more at one local store when compared to another.
    I've had no luck getting CC to upgrade my PSW 202 sub. I've talked to two stores and they both say the upgrade plan does not apply to subs. Other than that, the upgrade plan is awesome.
    When it is time for a sub, look at the HSU VTF-2. Santa is bringing me one for Christmas. :D
    My 7.1 setup consists of:
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RTi28s side surround
    FXi30s back surround
    PSW202 Subwoofer - Hey, it's my first sub!
    RCA 46" 4:3 RPTV
  • faster100
    faster100 Posts: 6,124
    Oh YES, the upgrade plan is for speakers.. a sub is a speaker.. I have upgraded every speaker i own plus 2 subs through circuit city, they make the rules as they go and no 2 stores/managers are the same it seems... I even upgraded a psw202 that i got for free through polks promo, buy 499 or more and get a free 202.. i took it in, added the extra cash and got the 404.. for last Christmas.. and i got it free. although they did put a note on the reciept that the upgrade had been used and not to allow a trade in with the 404 i had just got.. but at the time the 505 wasnt even out..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • KeithV
    KeithV Posts: 107
    Managers can set prices.
    I shop the local compitition somewhat often so that we make sure we have the lowest prices, and usually we are under the national ad that goes out. In some cases, such as high price TVs, we are up to $1k lower than the ad.
  • jkratzer
    jkratzer Posts: 148
    Well, I've had no luck in my area. I guess the store manager can modify the terms of the policy as they seem fit. I could drive further and try a third store but I'm thinking that I might be happier with the HSU VTF-2 or new HSU STF-2 than with a Polk PSW505 of Velo CHT-12.
    What do you think about the HSU VTF-2? I am only going off of what others have said on HomeTheaterForum.com and have never heard one in a sound room. It seems the HSU with its 10" woofer has bested subs costing $1000 or more with bigger woofers.
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RCA 46" 4:3 RPTV
  • Airplay355
    i did talk to the manager....but i didnt wanna ask him to lower the prices because 1 this is the second time i have used the upgrade policy, and 2 they are only supposed to upgrade pairs of speakers, not 2 for a whole system. atleast thats what 1 store said, but hey it doesnt bother me if i had to pay retail for them, i had already spent the money at CC anyway so its no biggie. what was i gonna do? ask for 2 pairs of rti70s a csi40 and fxi30s? i think not lol. oh well.
    now my damn left surround isnt working, time to open up the receiver and check the connection, cuz everything else is perfectly fine lol.
  • kberg
    kberg Posts: 974
    AAAAAHHHHHHHH!!! Another Polkie with a setup very similar to mine, which I think sounds excellent - you will too. Congrats!
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
  • Tour2ma
    Tour2ma Posts: 10,177
    Airplay,
    The CSi40 is now officially down to $299.99 at CC, so I see another price adjustment in your future...
    More later,
    Tour...
    Vox Copuli
