Experience with Monarchy?
Jetmaker737
Anybody familiar with these amps or their predecessor?
http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1262129057&/Monarchy-se-100-delux-mk2-sing
Thanks,
Jet
Thanks,
Jet
Post edited by Jetmaker737 on
Outstanding company, outstanding products, outstanding customer service. Truly a high end product for a decent price.
Those would handle just about any speaker you throw at it. What speakers specifically are you talking about?
I have a pair of these here now, they don't sound very good still in the box, need to get them outDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Thanks for the input guys!
My speakers are LSi-15'sSystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub -
Youre either lazy or have too much gear in rotation......
PaulyLife without music would♭ -
Jetmaker737 wrote: »Anybody familiar with these amps or their predecessor?
Thanks,
Jet
Thats a good price for New mono-blocs.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
thanks,,
Youre either lazy or have too much gear in rotation...... -
thanks,,
And you're a useless spammer...reported.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Anything from Monarchy is worth every penny you pay. Priced VERY fairly and Poon stands behind everything he makes. No customer service runaround either. You talk directly to the man himself if you have an issue. And I bet every issue is resolved, should there really ever be an issue, to complete satisfaction.Testing
Testing
Testing -
LOL too funny.Testing
Testing
Testing -
Is there a downside to pure class A other than perhaps heat?SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub
Jetmaker737 wrote: »Is there a downside to pure class A other than perhaps heat?
Nope, just heat. Some will chime and say heat affects longevity. There is some truth to that but the types of higher end amps (these included) use parts that are rugged enough and well built enough it's not an issue because they are designed to be used in a more rugged environment.
You'll find it'll take 30-60 minutes for you amps to sound their best simply because it take time for the bias to stabilize and the parts to get to their best operating temperature for the most liquid and open sound. My Aleph take about 45 minutes and sounds best after about 2 hours of being powered up."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Interesting... do you generally leave them powered on then? Or do they consume a lot of juice at idle?SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub -
Power consumption.
The high bias levels means that even when at idle it will draw more power from the wall than a similarily powered Class A/B design. Class A is only about 25% efficient vs the 40-50 % of Class A/B or the 90% of Class D.As a result much of the power drawn from the wall is waisted in heat instead of being used to drive the load.Testing
Testing
Testing -
My Pass draws 200 watts at idle (for a 30wpc amp) and it's full on at all times. I do leave it powered up if I know I'm going to be using the rig. It will raise the temp 2-4* in a 10' x 24' room.
My brother had the Monarchy SM70's the smaller version of the amps your considering and they ran warm but not hot at idle.
My Pass you can't leave your hands on the heat sinks for more than 5-7 seconds w/o lots of discomfort.
There are different definitions of class A as far how much bias is considered to be classified as class A. Some believe bias set at 2 to 2.5 times the rated continuous output is considered class A. Nelson Pass feels true pure single ended class A starts with a bias of 4 to 5 times the rated continuous output."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Class A is Class A,the question is to what power level can it sustain operation in that mode.Testing
Testing
Testing -
pure Class A operates to it's full output in class A."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
