Experience with Monarchy?
Jetmaker737
Jetmaker737 Posts: 1,123
edited November 2009 in 2 Channel Audio
Anybody familiar with these amps or their predecessor?
http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1262129057&/Monarchy-se-100-delux-mk2-sing
Thanks,
Jet
Post edited by Jetmaker737 on
    heiney9 Posts: 25,492
    Outstanding company, outstanding products, outstanding customer service. Truly a high end product for a decent price.
    Those would handle just about any speaker you throw at it. What speakers specifically are you talking about?
  • hoosier21
    hoosier21 Posts: 4,420
    I have a pair of these here now, they don't sound very good still in the box, need to get them out
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Jetmaker737
    heiney9 wrote: »
    Thanks for the input guys!
    My speakers are LSi-15's
  • Pauly
    Pauly Posts: 4,519
    hoosier21 wrote: »
    Youre either lazy or have too much gear in rotation...... :D
    Pauly
    Life without music would
  • danz1906
    danz1906 Posts: 5,144
    Thanks,
    Jet
    Thats a good price for New mono-blocs.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • glicapcin
    glicapcin Posts: 1
    SCompRacer Posts: 9,121
    glicapcin wrote: »
    thanks,,
    And you're a useless spammer...reported.
  • Systems
    Systems Posts: 14,872
    Anything from Monarchy is worth every penny you pay. Priced VERY fairly and Poon stands behind everything he makes. No customer service runaround either. You talk directly to the man himself if you have an issue. And I bet every issue is resolved, should there really ever be an issue, to complete satisfaction.
    Testing
    Testing
    Testing
  • Systems
    hoosier21 wrote: »
    LOL too funny.
    Testing
    Testing
    Testing
  • Jetmaker737
    Is there a downside to pure class A other than perhaps heat?
    Nope, just heat. Some will chime and say heat affects longevity. There is some truth to that but the types of higher end amps (these included) use parts that are rugged enough and well built enough it's not an issue because they are designed to be used in a more rugged environment.
    You'll find it'll take 30-60 minutes for you amps to sound their best simply because it take time for the bias to stabilize and the parts to get to their best operating temperature for the most liquid and open sound. My Aleph take about 45 minutes and sounds best after about 2 hours of being powered up.
  • Jetmaker737
    heiney9 wrote: »
    Interesting... do you generally leave them powered on then? Or do they consume a lot of juice at idle?
  • Systems
    Power consumption.
    The high bias levels means that even when at idle it will draw more power from the wall than a similarily powered Class A/B design. Class A is only about 25% efficient vs the 40-50 % of Class A/B or the 90% of Class D.As a result much of the power drawn from the wall is waisted in heat instead of being used to drive the load.
    Testing
    Testing
    Testing
    My Pass draws 200 watts at idle (for a 30wpc amp) and it's full on at all times. I do leave it powered up if I know I'm going to be using the rig. It will raise the temp 2-4* in a 10' x 24' room.
    My brother had the Monarchy SM70's the smaller version of the amps your considering and they ran warm but not hot at idle.
    My Pass you can't leave your hands on the heat sinks for more than 5-7 seconds w/o lots of discomfort.
    There are different definitions of class A as far how much bias is considered to be classified as class A. Some believe bias set at 2 to 2.5 times the rated continuous output is considered class A. Nelson Pass feels true pure single ended class A starts with a bias of 4 to 5 times the rated continuous output.
  • Systems
    Class A is Class A,the question is to what power level can it sustain operation in that mode.
    Testing
    Testing
    Testing
    pure Class A operates to it's full output in class A.
  • Systems
    Yes.
    Testing
    Testing
    Testing
