joint of two wires
kjaym71
Hi all,
Today I received 16 gaufe 100ft wire.
But the wire is little bit short.
- Can I joint old wire to my new wire(16 gauge)?
- If it's possible, should I just 'twist' two wires to joint(like electric wires)?
- Do you think there should be severe loss in sound quality?
Thanks,
Thanks,
Post edited by kjaym71 on
It's never an ideal situation, but yes, you could treat them just like an electrical connection. Twist them together and secure them with a wire nut and maybe some electrical tape. If you wanted to go nuts and help ensure that no oxidation occurs over time, you could solder them together and use a heat shrink wrap around the joint.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
WHAT are you using 100 ft of wire for? What speaker? What power output will you be running into it? For that length of run, you may require a higher gauge, depending on some other factors...TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
x2.
http://www.practical-home-theater-guide.com/home-theater-wiring.html
According to the above guide you should be using a minimum of 14GA wire for 100'.Speakers: Polk LSi 25, LSiC, LSiFX
Sub: Maelstrom X 18" DIY
Amps: Sunfire Sig Seven, Behringer EP-4000
Processor: Integra DHC-80.1
Monitor: Sharp LC 60E77UN
Sources: Motorola DCT-6416, PS3 Slim 250GB, Wii
Filter: APC S15 -
or put the speakers in the same room as the amp !!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Yes but...It's never an ideal situation, but yes, you could treat them just like an electrical connection. Twist them together and secure them with a wire nut and maybe some electrical tape. If you wanted to go nuts and help ensure that no oxidation occurs over time, you could solder them together and use a heat shrink wrap around the joint.
X3! Sometimes it is much simpler and provides for a better quality job to simply spend a few $$ to buy new wires and do the right job. Personally I don't twist and tape electrical wires for safety reasons... and nor do I twist and tape speaker wires for SQ reasons. Also, unless for very short distance I wouldn't use 16 gage anyway.WHAT are you using 100 ft of wire for? What speaker? What power output will you be running into it? For that length of run, you may require a higher gauge, depending on some other factors...
+1beardog03; or put the speakers in the same room as the amp !!
NOTE: If you still persist in connecting the wires together, the minimum would be to a proper junction (stay away from twisiting and taping).
Cheers
DARE TO SOAR:
Twist, wire nut, and (optional) electrical tape around the wire nut, all inside a box IS the proper way to do electrical. And it would work just fine for speaker wire, though as I stated it is not ideal for SQ reasons.Speakers: Polk LSi15
I don't like making in line speaker wire connections. I was forced to for my rear speakers after the dog ate the original wire and had nothing but problems with it. If the connection is not perfect, you'll get interference and maybe short out that channel. I used wire nuts and tape and the AVR still overloaded. Save yourself a headache, buy enough wire to make one run . . .Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
My rear speakers are using twists wires together for right now and no problems. Soon I will get a single run.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
IF you must, you should do it properly with some solder & heat shrink
Put a piece of heat shrink the length/size you need on the wire, twist the wire's together so that they stay like this ----, then solder and heat shrink! I have made MANY connection's this way on car's, boat's, equipment/machines, audio, etc, etc...
Make shure the wire's are clean and that you heat the wire first before applying the solder, this way it will flow well and form a solid connection. Also if you can, try to use a solder that is designed for electronic's use as it has better propertie's as compared to standard solder and usually has some form of flux.Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
Instead of starting a new thread I figured I could get an easy answer by bumping an old one. Ive read a lot around here about replacing the jumper on the double post speaker sets with a strand of speaker wire. Does this actually help much and for what reason? Also is this something one should do only if you are using both sets or if you dont have a bi-wire going on will it still help? Heading to lowes for some wire tomorrow and might pick up a few extra inches if this is something that would help. TIA
x2.
Thanks for the link I'm always wanting to learn
