Question on rti38
Picked up a new pair of rti38 from CC. Got home & they are too big for my a/v cabinets. They fit perfect in the cabinets laying on the sides, will this be ok or will it affect the performance. The cabinets are open. My second question should go in another forum, but I'll ask here. Using AR 16guage speaker wire & was told that Soundking 12guage wire would be a better choice on my budget. It's about $50 for 100ft at partsexpress.com inc. shipping. Thanks for any help given.
TV-Samsung HLN5065W DLP
Denon AVR-1803
Denon 2910 dvd player
Sony CE-345 CD Player
Philips CDR770 CD recorder
Center-CSI30
Fronts-rti38
Surrounds-RM6200
Sub-PSW202
Denon AVR-1803
Center-CSI30
Fronts-rti38
Surrounds-RM6200
Sub-PSW202
Post edited by jones12 on
Jones, congrats on the 38s. Firstly, placing the speakers on their sides will not affect performance, but placing them in a AV cabinet might. It will probably sound boomy, if you are concerned about performance place the 38s on stands so the tweeters are at ear level when seated. Second, 12 gauge is better if you can afford it but I dont know anything about the PE cable. Also try radio shack, home depot etc.Graham
Gate, thanks for the reply. The 38s are actually on top of the cabinets, which is about ear level. So far they sound great. The CC also had rt25i for $35 each open box, compared to the rti28 how are they?TV-Samsung HLN5065W DLP
Denon AVR-1803
Center-CSI30
Fronts-rti38
Surrounds-RM6200
Sub-PSW202 -
You're fine with the 38's, especially if you're using them in the front. I also have the Denon 1803. Great receiver. You'll learn to love your 38's. The just need a little time break in.
Hey, grab a pair of those 25's quickly for the back surround!!! Don't delay, do it today.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Sound King 12 GA is what I'm using and it is very good wire, much better than Home Depot wire. If you search on HomeTheaterForum.com you will find that alot of people recommend it.My 7.1 setup consists of:
Denon 3803
Panasonic DVD
RTi70s front
CSi40 front center
RTi28s side surround
FXi30s back surround
PSW202 Subwoofer - Hey, it's my first sub!
RCA 46" 4:3 RPTV
