Please explain.....
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited November 2009
    I will do that tomorrow and report back.
    1. Switch the HDMI cables.
    2. Switch the HDMI cables to different HDMI ports.
    3. Turn off the pure audio mode on the Denon.
    4. Turn off the PQLS control on the Pio.
    Hopefully, they both will be sound pretty much the same.
    This is unscientific and I need to know why.:confused:
    Try the set up as-is first, see if it's the same as what you heard before.
    Definitely turn off the PQLS. (I'd try that as the first change)
    In fact, now that I know what it does, I'd almost bet (if the difference is still there) that the jitter reduction processing is the culprit. That, or a dud cable/loose connector on the Denon.
