Wireless Light Dimmers
bigaudiofanatic
I am looking for some fixtures that will allow me to control my lights manually and wirelessly with my logitech remote. Does anyone knwo of a good one? I would only be using the wireless feature for movies.
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
Post edited by bigaudiofanatic on
Look at Lutron IR remote controlled dimmers. These replace your wall switch that controls the ceiling mounted light fixture. My Logitech Harmony One controls this dimmer very well.
Mikepolkaudio
Currently Own:
RTA-11T Light Oak, Aug/2011 to present
SDA-CRS+ Aug/2011 to present
RTA-11T Black, Dec/2013 to present
Previously Owned:
SDA-SRS 2.3 May/1990 to June/1991
SRS 1.2TL June/1991 to May/1995
SDA-1C Aug/2005 to Dec/2011
SRS 1.2TL Sept/2009 to Sept/2015 -
+1 on the Lutrons. I have the Spacer system in my HT/party basement with a master switch controlling 3 light circuits. ...all controlled by my harmony remote. figure out exactly what model numbers you need and then you can usually find NIB off ebay for much less than retail.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
You want the IR Lutron Spacer System. Add up the wattage of bulbs used and buy the dimmer that can handle the load. I.E 100w bulb+100w bulb+ 50w wall scounce = 250w so you would buy the 600w dimmer. The Spacer also allows 4 scenes as well. If you just want wireless dimmer then check out the IR Maestro dimmer sold at Home Depot.Shoot the jumper.....................BALLIN.............!!!!!
The scenes are what make you look smooth when the ladies are over. Be creative with the scenes, you have 4 of them. (IRL I only use 2 scenes.... "movie" and "regular". But it is nice to have that movie button on the Harmony once you get the Blu-ray in and all settled in the chair.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Thanks guys I will take a look at LutronsHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
I have not installed any dimmers, but have read they introduce noise into the AC circuit, which can degrade audio/video quality.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
This can be minimized by putting all of your lights on a separate circuit than your outlets. I get about 9% THD in my power (I'm talking 60hz AC power here... not THD from my amp) throughout my house which can be attributed to anything plugged in that has a DC converter on it, refrigerators, light dimmers etc. 9% is a little high, but not terrible. My 2-channel system plugged into a APC H10 power conditioner is dead silent. My HT through a Monster filter (can't remember product number) is very quiet. I can't notice any difference in sound or noise floor with the lights on or off.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Wow you guys get into that stuff way more than I do. I do not think I will have any problems. Now there are a lot of different controls on that site some include remotes others don't what should I be looking for? My light wattage will be 240 from the lights.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
The Spacer System dimmer that you would need is the SPS-600M-WH. If you want the master switch that can be used to program scenes, you also need. SPS-5WC-WH. You don't have to order the remote if you are going to use a harmony remote to control the switches. All of the codes will load into the remote when you add the lighting devices on the web interface.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
If you are going to be fancy and wire it as a 3-way switch you also need SPS-AD-WH for the other switch. You can't just use a regular 3-way switch.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
So what do you mean by set it for scenes do you mean like one mode for movies and one for music and so on?
So I need both the SPS-600M-WH and the SPS-5WC-WH? I only have one spot for the switch.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Yes you can set it for full on, scene 1 (half dim), 3/4 the way dim (movies), full off.
I suggest this website as it has everything you need. The Harmony remote works perfectly with the Lutrons as well.
As mentioned u want the 600w capacity dimmer w single pole configuration. Dont forget to add matching faceplate
http://www.beverlyhillselectric.com/spsincand.htmlShoot the jumper.....................BALLIN.............!!!!!
So I need both of them?HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
No you need one dimmer per 600 or 1000w.Shoot the jumper.....................BALLIN.............!!!!!
Okay so all I need is the SPS-600M-WH thanHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
bigaudiofanatic wrote: »Okay so all I need is the SPS-600M-WH than
Yes with face plate color of your choice and remote if you dont have Harmony
http://www.beverlyhillselectric.com/sps600.html
http://www.beverlyhillselectric.com/cw1.html
http://www.beverlyhillselectric.com/sps4itrp.htmlShoot the jumper.....................BALLIN.............!!!!!
Sweet ya I knew about the face plate so all I need is that SPS 600M and I am set. Than I program my remote for that and how dim I want it. That is what I think happens. lolHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Hi all,
I currently have two SPS-600 and one SPS-1000 in a three gang box.
Works great but I'm having some problems programming the scenes with my Harmony One remote. Downloaded the Lutron Spacer s/w for the remote from Logitech website and now have scenes 1 to 4 on the touch screen. But, how do I program them to different lighting levels?
When I press them I get 100/75/50/10 % light levels.
I know the Lutron remote needs keeping the button pressed for 3-4 secs until the light flashes to program a scene level. How do you re-program different lighting levels for the 4 scenes using the Harmony One?
Thanks.
Don
