PSW10 Constant Hum
Hello all Polk Club members. I am reaching out to you for some assistance with my home theater setup. I have a PSW10 connected to a ONKYO TX-SR606 7.1 Receiver via the PreOut connection. About a month ago I decided to take advantage of the prewired RG6 cable that my media room was prewired with and connect the sub/receiver using this.
So what I have not is Receiver -> RCA -> Wall Outlet -> RG6 -> F-Connector/RCA converter -> RCA -> Y-Connector ->Sub.
Whenever I have the sub connected directly to the receiver (RCA cord) no hum. Then when I use the RG6, hum. I can turn the hum up via the volume control on the sub. I have looked around and see that some suggest that it might be interference via the cords/grounding. I don't believe this to be issue, since the sub is connected to a power strip and is the only customer on it.
Any help would be a appreciated and if you can help me remedy the situation, you are more than welcome to come over and watch Dark Night to break in my new configuration.
Thank you.
"All that we see or seem
Is but a dream within a dream." - Edgar Allan Poe
Post edited by XBOX360_GAMER on
  • XBOX360_GAMER
    XBOX360_GAMER Posts: 2
    edited November 2009
    Got my own fix...I connected the RG6 incorrectly. First I used screw on connectors, and there was no signal. Then tried direct connecting without a connector = constant hum. Went to HD and got a RG6 cable connector set and did the crimp on connectors. Worked flawlessly...
    Moral of the story, when DIY cable connections, do it how the pros do it and don't think you know a better way.
  • dorokusai
    dorokusai Posts: 25,576
    Glad to read that, turn that thing up!
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    Not to loud lol it might distort like mine. Meaning the gain.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
