An ic comparison
rubin
rubin Posts: 565
edited October 2009 in 2 Channel Audio
I've been using tributaries cables between the preamp and amp for a few years.these cales are identified....a2 tributaries silver connect audio cable...they cost me $200.00 for the pair and are 6 feet long. I swaped in a pair of cheap brand x cables with the result being less detail,less brightness,less edgy.hate to say that i like them more, as i prefer a laid back duller sound.
Post edited by rubin on
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    This topic was discussed yesterday in this thread:
    http://www.polkaudio.com/forums/showthread.php?t=90336
    Perhaps it will give you some insight.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
    heiney9 Posts: 25,492
    edited October 2009
    It's the silver.................try a comparable pair of copper I/C's (comparable to the tributaries that is). If you still like the "generic" cables you just bought, then you just saved yourself some money and treat you and a significant other to dinner.
    edited October 2009
    A nice budget pair to try would be Signal Cable Analog II's. If you don;t like them you could flip them here for no loss.
  • rubin
    rubin Posts: 565
    edited October 2009
    I also tried a pair or tributaries (subwoofer cables) I had laying around and they sounded in between the silvers and the generic cables.Just having some fun experimenting and thought I'd share it.Between all 3 pairs it's not a huge difference though,just a little cost free tweaking.
    edited October 2009
    In the end it IS the subtle differences that seem to matter over time. Keep experimenting that's what this hobby is all about.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2009
    never waste audio funds on food--It's an Audio Man Rule.
    RT1
  • rubin
    rubin Posts: 565
    edited October 2009
    RT1
    I shall obey!!
  • rubin
    rubin Posts: 565
    edited October 2009
    Thanks for the reply Heiney.
