So which speaker wire do you guys use?
digitalvideo
digitalvideo Posts: 983
I was going to comment on the thread called: "Speaker wire test" but that got out of control and that thread was closed. So to keep it short which speaker wire is the best bang for the buck for a 7.1 surround system?
I use Bluejeans 5000ue for speaker wire and Bluejeans LC1 for sub wire. Can I get the same performance for less money with RadioShack speaker wire? Another other companies have a better bang for the buck?
Post edited by digitalvideo on
  • Willow
    Willow Posts: 11,228
    edited October 2009
    I use AQ indigo. Best so far I've tried.
  • thuffman03
    thuffman03 Posts: 1,325
    edited October 2009
    Some 12g wire that the guy from an audio shop gave me. I have no idea what brand.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • danz1906
    danz1906 Posts: 5,144
    edited October 2009
    Jonbiltcable custom Bi-wire cable.
    http://www.polkaudio.com/forums/showthread.php?t=84140
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • John K.
    John K. Posts: 822
    edited October 2009
    DV, it's a bit of a stretch to even use the term "performance" in reference to pieces of copper wire. Local sources of hardware such as Home Depot and Lowes have wire at somewhat lower cost which does this very simple job as well as anything. Among lower cost online sources is MonoPrice.
    If you haven't studied the basic facts of speaker wiring as explained here by a veteran audio professional, it'd be of benefit to do so. Over the past few years this has helped many avoid the wire charlatans who pollute our hobby.
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    ^Oh FFS.
    Go away.
  • BottomFeeder
    BottomFeeder Posts: 1,684
    edited October 2009
    Oh goody!
    Here we go!
    "Wish I didn't know now what I didn't know then." Bob Seger
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    AQ type 4 fronts and center. WalMart 14ga from the automotive section on the rears. The crap in the electronics department sucks.
    Ben
    F1nut Posts: 51,713
    edited October 2009
    John K. wrote: »
    Wow, that's just sad....make that pathetic. :rolleyes:
  • ben62670
    edited October 2009
    Reported post 10.
    John is still pushing the woger wusell $hit.
    Yawn
    Ben
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited October 2009
    I haven't spent much time with my wires, although I know I need to. Right now I just have some Rocketfish 14 or 16 AWG stuff that I upgraded my old HTIB wiring from and wow what a difference from that stock junk. I am waiting on a set of AQ Type 4's to audition (thanks to the great folks here at Club Polk, and AQ) so I am eagerly waiting on those to arrive so I can see what I have been missing.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • digitalvideo
    edited October 2009
    So is the Bluejeans 5000ue speaker cable wire I'm using a good wire?
  • wutadumsn23
    edited October 2009
    I have no personal experience with it, but have heard good things about Bluejeans wires/cables.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • mantis
    mantis Posts: 17,329
    edited October 2009
    I use Kimber , Audioquest , DH labs , Analsys Plus , Liberty , Tributaries depending on my mood.
    Dan
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    Buy the good stuff in bulk and terminate it yourself ;) A lil' bit of Techflex, heatshrink and some nice nanner's go a LONNNNNNNNNNG way! lol
    $1k cable's only cost a fraction to make yourself :)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • wutadumsn23
    edited October 2009
    I wouldn't go that far, lol. I don't think I could duplicate a set of MIT's for pennies on the dollar, lol. :D
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • rubin
    rubin Posts: 565
    edited October 2009
    I'm just using 12 awg "audoiphile" speaker wire (a buck a foot) stuff. I guess it's ok. Any suggestions on a reasonable penny pinchers upgrade? Four runs of 10 ft. each for bi-amping.
  • sTiLlLeArNiNg
    edited October 2009
    -Jeff
    Actually if you know about electronic's and where to source the part's you could. Seriously ;)
    Media Room 7.1
    HTPC
  • rubin
    rubin Posts: 565
    edited October 2009
    Keiko wrote: »
    Looks Good!thanks.
    edited October 2009
    Those are good places to start...unless you're independently wealthy, it's a good idea to buy 'used' wire if you're going for better quality..most of us boys and girls can't afford that MIT stuff new and even used it ain't cheap! But it is 'cheaper'.
    As for me...for now...I'm commiting the cardinal sin....I have some really old Monster 12 gauge that I use on the Adcom. When I'm able to afford to experiment with other cabling I will certainly experiment. I can say though that the old Monster is definitely better than brand X...
    cnh
  • sTiLlLeArNiNg
    edited October 2009
    Media Room 7.1
    HTPC
  • jinjuku
    jinjuku Posts: 1,523
    edited October 2009
    -Jeff
    I wouldn't call MIT's product 'cables' either. With a big box containing a LCR network sitting in the middle I think they are entirely something else.
  • wutadumsn23
    edited October 2009
    jinjuku wrote: »
    I wouldn't call MIT's product 'cables' either. With a big box containing an LCR network sitting in the middle I think they are entirely something else.
    Was just using it as an example is all.
    HT Rig
    Blu-Ray- 80 GB PS3
  • phuz
    phuz Posts: 2,372
    edited October 2009
    Kimber 8tc.
    Haven't seen anyone pull off a home made litz.
  • dvran
    dvran Posts: 280
    edited October 2009
    monoprice.com
    ~Dan
    Projector: Epson 705HD on 106" DaLite
    TV: Samsung 50" Plasma PN50B550
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    Sub: Velodyne Minivee 10
    PS3 and Xbox
  • shack
    shack Posts: 11,154
    edited October 2009
    Signal Cables.
  • fbm211
    fbm211 Posts: 1,488
    edited October 2009
    DH.Labs.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited October 2009
    Walmart cheapy, plastic wrapped spool of 12ga. from the car stereo section.
    NOT MON$TERD!!!
    tonyb Posts: 33,069
    edited October 2009
    Reality cables,good bang for your buck,stiff as all hell though. Various IC's,Mac palladium soundpipes,Bogden,Bens silver and a few others.
  • jinjuku
    edited October 2009
    shack wrote: »
    Signal Cables.
    Yep, gotta get those REFERENCE quality cables...
    From the Signal Cables website:
  • shack
    shack Posts: 11,154
    edited October 2009
    Yawn...
