Split A/V From Coaxial Cable
Cpyder
I've managed to figure out how to get my video and audio from their respective sources (Xbox 360, PS2, Computer, etc...) sent to the right places (Eg, Video to tv (of course!
) and audio to the receiver to play through my 2.0 channel system.)
One problem remains. How do I get my cable TV signal (which is delivered using a coaxial cable) split so the audio can be played through my speakers and not through the tv's built in speakers. My receiver does not have a coaxial input.
I'm guessing I need to buy some sort of splitting box, correct?
Thanks.
Thanks.
Post edited by Cpyder on
Splitting the coaxial cable won't necessarily send the audio to the receiver alone for many reasons. If you really think about it, what you're proposing is the way you'd add a splitter to send cable tv to 2 different televisions. Your receiver does not have a built in tuner to deal with any audio/video sent over the cable, plus you wouldn't be able to change channels from a single cord if for some reason you were ever to hook up the cable to your receiver lol.
It's better to look at your TV. Any audio RCA/optical outputs on it? What I did many years ago is hook up my cable box to a "hi-fi" stereo vcr. From there, I used the coaxial out on the vcr to go to my tv and used the audio-out (rca) from the vcr to my receiver. The only thing here is though, you'll need your tv on chan 3/4 (if using coaxial) or video input (if using composite from your vcr).
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
-Freddy
I never thought about the "receiver not having a tuner" part. So if I split the cable, the tv would be able to change the channel and such but the receiver would not know about this change and the audio would not change. (and/or would not be present at all because the receiver wouldn't know how to deal with the signal) I don't think my tv has any audio outs.
Hmmm... the vcr idea is looking better. There's got to be something cleaner, right? -
Thats the cheaper/easy solution I used during highschool. Of course I bought my vcr new, but nowadays you can snag one on cl for about $10 bucks...even a good model. Got the funds down the road for a newer/better TV?Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
A new tv is scheduled for pretty far down the road probably. Besides waiting for OLEDs to come down in price, I'm also transitioning from undergrad to grad school/full time job. (Haven't decided 100%) Which means, right now, not a lot of money for a new tv. -
Right now, it's just a 37" 720p Vizio. Not horrible, but nothing to write home about. lol
Minimize Polk forum, open new tab->craigslist->electronics->VCR
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Hmm, is it an LCD/plasma or the tube-type television?
Anyway no matter, you should just check to see if it has a set of audio outputs. Just take a look yourself, wouldn't hurt.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Most panels have audio outputs.
panel out ---> receiver-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Audio out's on the panel or a VCR/cable box, i run a toslink from my cable box to my AVR work's great!
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
sTiLlLeArNiNg wrote: »Audio out's on the panel or a VCR/cable box, i run a toslink from my cable box to my AVR work's great!
I did that too from my cable box seeing as it has RCA outputs (1 set variable, 1 set fixed), toslink and hdmi out. I'm assuming he has no cable box seeing as he said he runs the coaxial cable straight to his tv
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
I think that is a safe assumption, did you try connecting with the various option's on your setup if so what did you like best?
I tried HDMI and toslink only, i preffered the toslink as i was getting some "handshake" going on with the HDMI running through the receiver. I found it much better routing HDMI directly to the panel and toslink to AVR
Media Room 7.1
HTPC
sTiLlLeArNiNg wrote: »I think that is a safe assumption, did you try connecting with the various option's on your setup if so what did you like best?
I just used toslink from my cable box to the Denon AVR2805 I was using since it didn't have hdmi ins/outs. A beast of a receiver so never had the need to pick something new up. Now that I think about it though.....I never even bothered watch movies on cable or even on-demand. Only on the BDP/DVDP
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
From the GFX card/sound card on my HTPC to my AVR/panel is a pair of HDMI's but we watch a lot of flic's through HDTV so the toslink was a must IMHOMedia Room 7.1
HTPC
LCD. I gave it a good look down and could not find any audio outs. Tonight, I'll move the speakers and actually get behind the tv to look. But I'm quite sure it doesn't. -
Alright.
Though I'd be surprised if it didn't have any. Mine has several component and composite inputs as well as hdmi, and my analog/composite outputs are next to a set of those. At first glance they look like inputs but upon further inspection....one of them is actually a set of outs!
Hopefully your TV has them though.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Alright.
Though I'd be surprised if it didn't have any. Mine has several component and composite inputs, and my analog/composite outputs are next to a set of those. At first glance they look like inputs but upon further inspection....one of them is actually a set of outs!
Same here.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
glenfoxman wrote: »Hmmm... Im using encrypted Grh on my game, so every time I need one .jpg to be loaded my game decrypt the <number>.gfx into a <number>.jpg, load it and delete it...
But not creating a new file every time should be really good, right? ;B
_______________________________________
Website I designed for instant payday loans company.
WTF???
Look at his posts amount. Probably just a bot. Or someone just being stupid.
That's what I was thinking as well.
Are you sure you have no audio outs from the back of your TV. I have a 19" lcd in our guest bedroom and it has tonns of ins and outputs. -
I was about to ask that again lol.
I'm certain he has outs on his tv, he just hasn't looked and/or found them yet? :eek:Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Checking right this second...
Waiting for it....-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
No. Unless I'm blind, but this is my tv:
http://www.walmart.com/Vizio-32-LCD-HDTV-VW32L/ip/5623472
This may be a newer model, but it doesn't mention audio outs.
And by newer model, I mean same damn thing but newer year, but they may have changed the color of the LED for example. lol
Wow, I guess not then. I've got an Insignia TV and it has ins/outs for everything.....so not like I'm running anything hi-end/crazy either.
Well, guess you can try my stereo vcr idea now
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Wow. Bummer.
Yeah Kawizx9r's idea is the next best thing. Doesn't your cable provider give out set-top boxes? Perhaps you could get one of those. Even the SD versions have stereo outs.
A pawn shop oughta have one for cheap. Hell I'd give ya one if you were local.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
How about splicing the cables that go to the internal speakers and route that signal to my receiver?
Or would that be crossing the line of respectability. -
And just plain wrong. The speakers are amplified. You need a line level for your receiver.
Do what kawizx9r suggested and find a cheap VCR. Done.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
I've got one left over from a car project
