Split A/V From Coaxial Cable
Cpyder
Cpyder Posts: 514
I've managed to figure out how to get my video and audio from their respective sources (Xbox 360, PS2, Computer, etc...) sent to the right places (Eg, Video to tv (of course! :)) and audio to the receiver to play through my 2.0 channel system.)
One problem remains. How do I get my cable TV signal (which is delivered using a coaxial cable) split so the audio can be played through my speakers and not through the tv's built in speakers. My receiver does not have a coaxial input.
I'm guessing I need to buy some sort of splitting box, correct?
Thanks.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    Splitting the coaxial cable won't necessarily send the audio to the receiver alone for many reasons. If you really think about it, what you're proposing is the way you'd add a splitter to send cable tv to 2 different televisions. Your receiver does not have a built in tuner to deal with any audio/video sent over the cable, plus you wouldn't be able to change channels from a single cord if for some reason you were ever to hook up the cable to your receiver lol.
    It's better to look at your TV. Any audio RCA/optical outputs on it? What I did many years ago is hook up my cable box to a "hi-fi" stereo vcr. From there, I used the coaxial out on the vcr to go to my tv and used the audio-out (rca) from the vcr to my receiver. The only thing here is though, you'll need your tv on chan 3/4 (if using coaxial) or video input (if using composite from your vcr).
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    kawizx9r wrote: »
    -Freddy
    I never thought about the "receiver not having a tuner" part. So if I split the cable, the tv would be able to change the channel and such but the receiver would not know about this change and the audio would not change. (and/or would not be present at all because the receiver wouldn't know how to deal with the signal) I don't think my tv has any audio outs. :( Hmmm... the vcr idea is looking better. There's got to be something cleaner, right?
  • kawizx9r
    edited October 2009
    Thats the cheaper/easy solution I used during highschool. Of course I bought my vcr new, but nowadays you can snag one on cl for about $10 bucks...even a good model. Got the funds down the road for a newer/better TV?
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    kawizx9r wrote: »
    A new tv is scheduled for pretty far down the road probably. Besides waiting for OLEDs to come down in price, I'm also transitioning from undergrad to grad school/full time job. (Haven't decided 100%) Which means, right now, not a lot of money for a new tv.
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    Right now, it's just a 37" 720p Vizio. Not horrible, but nothing to write home about. lol
  • kawizx9r
    edited October 2009
    Cpyder wrote: »
    Minimize Polk forum, open new tab->craigslist->electronics->VCR :)
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    edited October 2009
    Cpyder wrote: »
    Hmm, is it an LCD/plasma or the tube-type television?
    Anyway no matter, you should just check to see if it has a set of audio outputs. Just take a look yourself, wouldn't hurt.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    Most panels have audio outputs.
    panel out ---> receiver
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    Audio out's on the panel or a VCR/cable box, i run a toslink from my cable box to my AVR work's great! :)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • kawizx9r
    edited October 2009
    I did that too from my cable box seeing as it has RCA outputs (1 set variable, 1 set fixed), toslink and hdmi out. I'm assuming he has no cable box seeing as he said he runs the coaxial cable straight to his tv :confused:
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • sTiLlLeArNiNg
    edited October 2009
    kawizx9r wrote: »
    I think that is a safe assumption, did you try connecting with the various option's on your setup if so what did you like best?
    I tried HDMI and toslink only, i preffered the toslink as i was getting some "handshake" going on with the HDMI running through the receiver. I found it much better routing HDMI directly to the panel and toslink to AVR :o
    Media Room 7.1
    HTPC
  • kawizx9r
    edited October 2009
    I just used toslink from my cable box to the Denon AVR2805 I was using since it didn't have hdmi ins/outs. A beast of a receiver so never had the need to pick something new up. Now that I think about it though.....I never even bothered watch movies on cable or even on-demand. Only on the BDP/DVDP :)
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • sTiLlLeArNiNg
    edited October 2009
    From the GFX card/sound card on my HTPC to my AVR/panel is a pair of HDMI's but we watch a lot of flic's through HDTV so the toslink was a must IMHO
    Media Room 7.1
    HTPC
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    kawizx9r wrote: »
    LCD. I gave it a good look down and could not find any audio outs. Tonight, I'll move the speakers and actually get behind the tv to look. But I'm quite sure it doesn't.
  • kawizx9r
    edited October 2009
    Cpyder wrote: »
    Alright.
    Though I'd be surprised if it didn't have any. Mine has several component and composite inputs as well as hdmi, and my analog/composite outputs are next to a set of those. At first glance they look like inputs but upon further inspection....one of them is actually a set of outs!
    Hopefully your TV has them though.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    kawizx9r wrote: »
    Alright.
    Though I'd be surprised if it didn't have any. Mine has several component and composite inputs, and my analog/composite outputs are next to a set of those. At first glance they look like inputs but upon further inspection....one of them is actually a set of outs!
    Same here.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Willow
    Willow Posts: 11,367
    edited October 2009
    glenfoxman wrote: »
    Hmmm... Im using encrypted Grh on my game, so every time I need one .jpg to be loaded my game decrypt the <number>.gfx into a <number>.jpg, load it and delete it...
    But not creating a new file every time should be really good, right? ;B
    _______________________________________
    Website I designed for instant payday loans company.
    WTF??? :confused:
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    Willow wrote: »
    WTF??? :confused:
    Look at his posts amount. Probably just a bot. Or someone just being stupid.
  • Willow
    edited October 2009
    Cpyder wrote: »
    That's what I was thinking as well.
    Are you sure you have no audio outs from the back of your TV. I have a 19" lcd in our guest bedroom and it has tonns of ins and outputs.
  • kawizx9r
    edited October 2009
    Willow wrote: »
    I was about to ask that again lol.
    I'm certain he has outs on his tv, he just hasn't looked and/or found them yet? :eek:
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    Checking right this second...
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    Waiting for it....
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • kawizx9r
    edited October 2009
    vc69 wrote: »
    Waiting for it....
    +1
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    No. Unless I'm blind, but this is my tv:
    http://www.walmart.com/Vizio-32-LCD-HDTV-VW32L/ip/5623472
    This may be a newer model, but it doesn't mention audio outs. :(
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    And by newer model, I mean same damn thing but newer year, but they may have changed the color of the LED for example. lol
  • kawizx9r
    edited October 2009
    Cpyder wrote: »
    Wow, I guess not then. I've got an Insignia TV and it has ins/outs for everything.....so not like I'm running anything hi-end/crazy either.
    Well, guess you can try my stereo vcr idea now :)
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    Wow. Bummer.
    Yeah Kawizx9r's idea is the next best thing. Doesn't your cable provider give out set-top boxes? Perhaps you could get one of those. Even the SD versions have stereo outs.
    A pawn shop oughta have one for cheap. Hell I'd give ya one if you were local.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    How about splicing the cables that go to the internal speakers and route that signal to my receiver?
    Or would that be crossing the line of respectability.
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    Cpyder wrote: »
    And just plain wrong. The speakers are amplified. You need a line level for your receiver.
    Do what kawizx9r suggested and find a cheap VCR. Done.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    I've got one left over from a car project :) ...
