PSW 10 Connection
charrell
charrell Posts: 1
I have a PSW 10 connected to a Pioneer 01thx and the Reciever looses the sub when powered down. I have tried to use both settings on the sub for auto and off. I have also used both settings on the reciever for a sub. The sub is connected from the sub out on the reciever to the left chanel on the PSW 10. I have to unplug the sub and plug it back in with the reciever turned on to get it to play. I know it is probably something simple that I'm over looking but I just don't see it.
Post edited by charrell on
  • danger boy
    danger boy Posts: 15,722
    edited October 2009
    what setting does it lose? does your receiver say that you have no sub connected to it?
    I leave (sub) mine on.. so that it plays whenever a signal is passed through to it. i guess same as leaving it on standby.. and it's suppose to activate when it senses a audio signal.
    if your Pioneer receiver is losing it's sub.. it then would be a problem with the receiver and not the sub. check the menu settings for the Pioneer.. and maybe you have to hit a button to remember it's settings.. like SAVE. I have to do that on my Outlaw Audio pre amp after I calibrate it every time or else it won't remember the current settings.
    good luck.
    PolkFest 2012, who's going>?
  • danger boy
    edited October 2009
    Oh yeah.. welcome to Club Polk. Lots of helpful people in here.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited October 2009
    I have a pioneer receiver and a psw10 sub. Mine is set to auto and takes a little bit of music at higher volumes until it realizes to turn on. If that helps any.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
