Room treatments
concealer404
Where do you all buy your room treatments? I'm in desperate need of some, but i also don't really have the budget to drop a ton of money on them, either.
I probably need 4 decent size panels to start. Pretty patterns or colors for optimum SOAF is a plus.
Post edited by concealer404 on
Build them!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I bought my OC 705 from these guys http://www.spi-co.com/directory.html
Local to you is
Insulation/Architectural
5230 Park Emerson Drive Suite O
Indianapolis, IN
USA
Wife made the covers. Made L bracket for bottom and loop near the top in the back for one of those fish hook looking hooks you push in the wall.
See my setup for pics.Speakers: SDA-1C (most all the goodies)
-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Room treatments are so under rated. Look into first reflection, and then behind you.
Ben -
Those are nice but for 1 2'x4' 2" you could buy 3 from the site above. If you or your SO is handy with a sewing machine you can make your own to match your decor.Speakers: SDA-1C (most all the goodies)
Local to you is
Indianapolis, IN
USA
Hrmmm.... What did she use for the covers?
I may give them a call, that's right down the road from me.
Thanks!I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Ben
No doubt. After some dinking around I did last weekend, I am convinced that the 6 panels I am buying (about $300) will be the most significant upgrade to my system I can make.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
My current SO is a danger to herself and others with regard to sharp objects, etc.
Thanks for the pointer though, I'm going to take a look at their offerings.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
concealer404 wrote: »Hrmmm.... What did she use for the covers?
Thanks!
Take a look at this thread on AVS about making panels:
http://www.avsforum.com/avs-vb/showthread.php?t=487747
Most people cover them in GOM (Gilford of Maine) fabric. -
Thanks!
Fabric from Hancocks. Just make sure you can easily blow threw the fabric. You do not want anything heavy like burlap.Speakers: SDA-1C (most all the goodies)
I'll probably want a total of four 2x4 panels. I apologize for asking dumb questions, but i can't call them until tomorrow, stuck at work at the moment.
How much did yours end up costing and how many/what sizes did you do?
This idea has been in the back of my head for awhile, but after Nik's visit on Saturday, i realized just how bad this room sounds. It's AWFUL, and neither of us could believe that my system even sounded as good as it does in this room.
Sooo... room treatments > DAC at the moment.
The Owens Corning 703s were about $10 and the 705s were about $12 from what I remember. I used 705 2"x2'x4'
I used 5 panels. I could use more but I have a huge fireplace that is basically a wall and I was not allowed to treat it.
It did help.Speakers: SDA-1C (most all the goodies)
Oh nice! Looks like i can easily do this for a good chunk under $100 when all is said and done, and this way i can actually put them together in the apartment without making a mess.
Thank you sir!I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Owens Corning 705 is about as good as it gets for absorbing! Standing it off from the wall does increase it's effectiveness...as in going lower. The best treatment is for it to be very broad and not all centered at one narrow frequency band.
I built using 2" 705 in 2' X 4' frames that I stood off another 2" from the wall. I found them to be very effective! I put the first pair a little to the side from in line behind the speakers (dipolar). Then centered the next one on the front wall...which seems to have a great impact. Then I put the next pair on the side walls. Then the last one (I've got made so far) directly behind the listening position.
It is some of the best money you can spend!! Good luck!
CoolJazzA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
I was planning on putting one behind each main, probably slightly towards the inside of both of them, and then two right up next to each other, essentially making a 4x4 behind the listening position.
I only have one side wall, and it's unfortunately a sliding glass door, so i can't do much about that.
concealer404 wrote: »Oh nice! Looks like i can easily do this for a good chunk under $100 when all is said and done, and this way i can actually put them together in the apartment without making a mess.
Thank you sir!
The covers are a little tricky. I used plastic corner trim cut to fit the width for the corners. MY wife tried a zipper across the top but ultimately machine sewed 3 sides, slip the panel in and hand sewed the top. Mine sit 1" from the wall but as someone said more is better.
Used hot glue to hold the corners on. You could try it without it but I was afraid the insulation would break down on the corners fitting it into the the bag.Speakers: SDA-1C (most all the goodies)
Hrmmm... i'm having a hard time visualizing this. I think i'll pop down there this weekend and get the panels ordered, and then i'll probably bug you from there, if that's alright with you?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Hrmmm... i'm having a hard time visualizing this. I think i'll pop down there this weekend and get the panels ordered, and then i'll probably bug you from there, if that's alright with you?
No problem. Here is a tutorial
http://www.readyacoustics.com/index.php?main_page=page&id=40&chapter=0
Go to Bagging your trapsSpeakers: SDA-1C (most all the goodies)
room treatments are goo
they are very good
so very good really
sometimes it can be good
but not so much goo
Wonder what is going to be offered FS ^^^-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
sorry guys trying to get post count up so i can post an ad for my lsi's.I will move on
Bad form. Been watching you spam up threads all morning.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I really need to get some treatments but i have been told NO lol.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
I started with a pair of them from ATS. I have no energy to build my own anything. I got the fire proof ones, and have since added several more pairs over the last couple of years. I have ten in my theater which is great with no big expense at any given time. The biggest impact was when I put them where the wall meets the ceiling. Highly recommended and ATS is a good value if you don't want to DIY.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
http://www.polkaudio.com/forums/showthread.php?t=65330
Best room and system I ever had..
http://www.polkaudio.com/forums/showthread.php?t=65567
Nik -
nikolas812 wrote: »http://www.polkaudio.com/forums/showthread.php?t=65330
Nik
Yep, i checked your threads out... but that level of DIY isn't really possible in my apartment setting.
