The Bittersweet Sound of Jitter
Cpyder
I've looked everywhere. I'd like a digital sample of what a jitterless piece of music sounds like and then one with jitter present.
Everywhere I've looked, people just start explaining what jitter is and then give some articles on the topic. This is exactly what I don't want.
I'd like someone to post an example of what jitter really sounds like, whether it be test tones or music.
Thank you so much!
Thank you so much!
Post edited by Cpyder on
Play the same disc in a cheap POS CDP and then in a $10K CDP, you will hear what you seek.Political Correctness'.........defined
President of Club Polk -
That shrill sound that makes it difficult to stomach the highs on CDs played on a cheap player...that's pretty nasty at higher volumes!
What I can't understand is that with all of the fantastic developments in PC power and processing...why can't we produce a cheaper CDP that virtually elimninates jitter? It would seem possible to design something that is not prohibitively expensive. All you would need is some sophisticated programing that monitored jitter and other feedback 'errors' and corrected them instantaneously along with some primo DACs.
Am I wrong...or is somebody missing at the wheel?
Technology costs money.Political Correctness'.........defined
They're coming, give it time."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
cnh
It's called a turntable. I have not listened to a CD in the house since I went back to black.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
The last thing I worry about in audio is jitter.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
That's not jitter. Try this site, they test many players for jitter levels:
http://www.milleraudioresearch.com/avtech/index.html
You have to register to read the reports. The results are quite suprising. For example, the best they tested was the Benchmark DAC1 PRE at 32psec. Others tested - Musical Fidelity A5.5 118psec, Rega Saturn 204psec, Sony BDP-S300 122psec, etc.
The only players that seem to have really high levels, were high end, high priced players, but even then, only a couple of them. Go figure. -
nooshinjohn wrote: »It's called a turntable. I have not listened to a CD in the house since I went back to black.
Trade jitter for rumble, pops, clicks, skips, etc.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
depends on the quality of the table, stylus, the LP and the volume it is being played at... Just like the CD players.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Anything less than 150ps is inaudible unlike rumble, pops, clicks, skips, etc.Political Correctness'.........defined
agreed Jesse, but at the volumes I listen and with the newer vinyl in my collection, I cannot hear the noises anyway, unless I need to get up off my **** and clean the stylus.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Does SACD/DVD-A have jitter?SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
Yes. Definitely.
And as far as switching between players to determine the jitter that is present, I'd think other variables would be more noticeable such as harmonic distortion and the like, thus I wouldn't know if I was hearing jitter or other distortions. -
nooshinjohn wrote: »agreed Jesse, but at the volumes I listen and with the newer vinyl in my collection, I cannot hear the noises anyway, unless I need to get up off my **** and clean the stylus.
Same here--Actually since I got my TT, I've only ever played old/used vinyl and heard the pops, clicks, etc--to an annoying degree actually even on what appears to be pristine vinyl. I figured that I just needed to learn how to properly clean the vinyl or perhaps replace the stylus or something.
Then the other day I bought a brand spanking new copy of Slipknot Vol 3 Subliminal Verses (vinyl of course) and to my utter shock and awe--I heard no such thing--completely dead silent background--and I had it turned up.
Now I'm siked to either get my old albums cleaned or buy some more new stuff.
I'd say to hear something with and without jitter (or attempt to anyway), compare Vinyl (pure analog) or perhaps even analog tape, to CD. Or perhaps do some listening comparisons with and without a highly rated DAC and /or Jitter reducer and see if that makes a difference.
Not sure if jitter makes its way into file from a ripped CD (assuming FLAC or raw WAV) or not, or if it only happens at playback time, or even if hard drive based files can have thier own jitter induced
Honestly I can't say I know what jitter sounds like.____________________
Pool: Atrium 60's/45's -
I've got to agree with nooshinjohn and mmadden28 on this. Ever since I've gotten into vinyl, I don't hardly ever listen to cds anymore. I thouroughly clean my records and they hardly ever make a snap, crackle, and pop, and have extremely quiet backgrounds. I don't have a several thousand dollar cd player and would probably listen to my cds more if I did, but to me the richness and life-like quality of vinyl is hard to beat. No jitter there!
http://www.stereophile.com/features/338/index14.html
Arthur SchopenhauerAll truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident. -
There is one thing us old vinyl junkies have that the CD folks will never have, a huge selection of great old tunes that will never be recorded on CD.
Every technology has it's drawbacks. The best way to hear the music the way it was intended is to go "source-direct" and see a concert once in a while.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I saw this guy trying to pour a drink one day he had more jitters than any cheap CDP.
Had we met?-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Maybe we have met but that guy is dead now.
Must not have your TT set-up properly and are playing dirty album's....
LOVE vinyl! MUCH MUCH better than digital media IMHO
I have less than $250 invested in my TT set-up, including a professional tune-up
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
I'm one of the lucky ones.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
sTiLlLeArNiNg wrote: »Must not have your TT set-up properly and are playing dirty album's....
Don't have a turntable. Been there, done that. For me, it is not worth the time, effort, or money.
Granted, new records sound great, but every time you play a record you do damage to it. It is impossible to argue otherwise. After you play the record enough, the damage becomes audible. Of course, this assumes you never drop a record, bump into the turntable while it is in use and the stylus slides over the record, or do something else that damages the fragile, delicate record.
As you say, you are still learning.
You could play an album countless time's and if you have a properly set-up table, good stylus (meaning one with a good tip not a high price) and take proper care of the album it will last as long as you need it to.
I will agree with you that vinyl is consumable but don't over exaggerate thing's, please.
Media Room 7.1
HTPC
Any disc source with a laser is prone to errors.
Interesting. They made a laser that reads vinyl and from what I understand it reads it too well.Political Correctness'.........defined
Vinyl is the wave of the future. We should try to leave that old CD technology where it belongs, in a computer...
If this is true, the laser would still need to sample the information. Which means its not analog anymore. -
What does Vinyl and BluRay has in common? I am sure BluRay discs will be the mainstream media for music and all things digital in the near future.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
