MW6500 Replacement
skrol
skrol Posts: 3,490
edited October 2009 in Vintage Speakers
I had noticed that one of my Monitor 5A's, depending on how evenly I presses the woofer in, had a little scratchiness. I can't swear that heard any when playing music. Since none of my other Polk MW's do this, I decided to replace it.
I was not sure if I should go with a new MW6502 from Polk or try to snag a vintage MW6500. Polk CS says that the MW6502 has the same Thiele / Small parameters as the MW6500. I have heard some say they prefer the MW6502.
If I replaced one with the MW6502, I figured I'd end up replacing both and cost me double. I also like the idea of keeping them all vintage. Therefore, I opted to find a used MW6500. I did find one, and probably paid too much, but the mfg date is within a month of my Monitor 5A's and it is like brand new. I can't say yet if it sounds better than the old one but it sounds good and I have peace of mind (and a spare MW6500).
Out of curiosity, anyone here compare the 6502 sound vs the 6500?
Stan
Main 2ch:
HT:
Other stuff:
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    The 6502 is 4ohms, and the 6500 is 8ohms. They are not interchangeable.
    Ben
  • skrol
    skrol Posts: 3,490
    edited October 2009
    I guess I made the right decision then.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,490
    edited October 2009
    I just asked Polk CS about the impedance and they realized that they told me the wrong replacement. The replacement should be the MW6503.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • ANWKLO
    ANWKLO Posts: 173
    edited October 2009
    ben62670 wrote: »
    If my Monitor 5 have already been replaced MW6500 by MW6502:confused:
  • ben62670
    edited October 2009
    Some 5's use 6502's and some use 6500's.
    Ben
  • ANWKLO
    ANWKLO Posts: 173
    edited October 2009
    ben62670 wrote: »
    My Monitor 5 original are MW6500:(
  • ben62670
    edited October 2009
    Paper surrounds?
    Ben
  • Ricardo
    Ricardo Posts: 10,634
    edited October 2009
    I've used 6502's in y monitor 7B's. No problems at all with the different impedance.
    SOPA
  • ANWKLO
    ANWKLO Posts: 173
    edited October 2009
    ben62670 wrote: »
    Paper surrounds?
    I can't hear any difference between MW6500 and MW6502:)
  • skrol
    skrol Posts: 3,490
    edited October 2009
    ben62670 wrote: »
    Paper surrounds?
    Were some of the MW6500 paper surrounds? Mine are rubber.
    As far as I know the Monitor 5A had the MW6500. I believe that the Monitor 5B used the MW6502. I also believe that the 5B has a larger cabinet. I have seen two specs for the Monitor 5B. apparently, the earlier versions were a 4 ohm system and later were 6 ohms.
    It would be interesting to do a comparison of the MW6500, MW6502, MW6503, etc.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • geppy1
    geppy1 Posts: 3,077
    edited October 2009
    I have compared the 6500,6600X and 6501. They all sound different. The 6500 and 6501 are more alike then different. Are you looking for a 6500 with the grey cardboard around the rim or not? keith
  • skrol
    skrol Posts: 3,490
    edited October 2009
    I actually picked up a MW6500 dated within one month of my originals. So, I am no longer in need.
    Thanks though
    Stan
    Main 2ch:
    HT:
    Other stuff:
