what do i have here thay say model 5
zippty2001
can some one tell what i have here about how old are they what kind a fuses do i need ? I tested them for a second they work but i need to get real fuses was this worth $35 ?
Post edited by zippty2001 on
Very good find. The tweeters alone are worth the $35. You use 1 amp fast blows on the tops, and 2 amp fuses on the bottom IIRC. They appear to be 5's with the 8" passive radiator. Year would be roughly determined by pulling the middle driver out.
Ben -
Where'd you find those? I didn't see those.
Usually they would say MW6500 and a year. Like you said they must be old. The grill attachment setup would indicate an older model also.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
wow they sound good so i they have the peerless tweeter is this better than the sl2000 or 3000 hows this brake down i am trying to find something on this
and if so would this be good for puting in my rta 11t ??? -
you can try,I think the peerless and sl2000's are interchangeable. you might wait for a second opinion. I just put some RDO 194's in my rta 11t's and they sound great.
the peerless would need an extra resistor.
Take a look at your(the Model 5's) xover and compare to a reg Mon 5 wiring diagram.
I know in the Mon 7's it is around 6.2 ohm.
IDK what it would be in a RTA 11, since there is not a "Peerless" version of those.
I have not personally compared the Peerless to other tweets yet, but 'I have read' that the RDO's are still better....bu the Peerless would definately be a step up from the SL2000's....
great find...
zippty2001 wrote: »wow they sound good so i they have the peerless tweeter is this better than the sl2000 or 3000 hows this brake down i am trying to find something on this
Congrats on the Good find!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
They aren't interchangeable with the sl2000. The x-over is different. The RD0 is slightly larger than the peerless so some wood working with a dremel on the tweeter opening would be nec on the Monitor 5's.
As far as the 11T, just get the RD0194-1 if you have sl2000's and are looking for replacement tweeter that sounds a thousand times better.
Also, the Monitor 5 (Peerless) XO's vary. While some have the 6.2 ohm, mine have 2.5 ohm (built in 1983). I have been working with Polk CS to try to figure which would be better.Stan
Main 2ch:
HT:
Other stuff:
hay skrol i sent you a pm the other day about about your rta upgrades. can you give me some info please on what you used for the xover and stuff. i want to start on mine soon and i am looking for info on what to do thanks allot. -
are those monitor 5's?PolkFest 2012, who's going>?
danger boy wrote: »are those monitor 5's?
Yes, very early Monitor 5's as evidenced by the drivers, cabinet, grill attaching method and double fuses."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
zippty2001 wrote: »hay skrol i sent you a pm the other day about about your rta upgrades. can you give me some info please on what you used for the xover and stuff. i want to start on mine soon and i am looking for info on what to do thanks allot.
I just sent the PMStan
Main 2ch:
HT:
Other stuff:
Amen. Why hack an excellent speaker, and kill a true classic.
Don't blow those tweeters!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I love how thick the top, bottom and sides of the cabinet are. My Monitor 5A's are rock solid but they are not that thick.Stan
Main 2ch:
HT:
Other stuff:
ya they are heavy i would guess 15 - 20 pounds a speaker i might be wrong
thanks for the help skrol i am not going to do any thing to the m5s i might sell them to help me with my rta 11 upgrades but i don't know yet the cabinets are in OK shape they have a lot a ware and tare but for how old they are they are in good shape...
