what do i have here thay say model 5
zippty2001
zippty2001 Posts: 232
edited October 2009 in Vintage Speakers
can some one tell what i have here about how old are they what kind a fuses do i need ? I tested them for a second they work but i need to get real fuses was this worth $35 ?
Post edited by zippty2001 on
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    Very good find. The tweeters alone are worth the $35. You use 1 amp fast blows on the tops, and 2 amp fuses on the bottom IIRC. They appear to be 5's with the 8" passive radiator. Year would be roughly determined by pulling the middle driver out.
    Ben
    Ben
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    Where'd you find those? I didn't see those. :p
  • zippty2001
    edited October 2009
    here is the back of the speakers must be old
  • ben62670
    edited October 2009
    Usually they would say MW6500 and a year. Like you said they must be old. The grill attachment setup would indicate an older model also.
    Ben
  • zippty2001
    edited October 2009
    wow they sound good so i they have the peerless tweeter is this better than the sl2000 or 3000 hows this brake down i am trying to find something on this
    and if so would this be good for puting in my rta 11t ???
  • zarrdoss
    zarrdoss Posts: 2,562
    edited October 2009
    you can try,I think the peerless and sl2000's are interchangeable. you might wait for a second opinion. I just put some RDO 194's in my rta 11t's and they sound great.
  • kcoc321
    kcoc321 Posts: 1,788
    edited October 2009
    the peerless would need an extra resistor.
    Take a look at your(the Model 5's) xover and compare to a reg Mon 5 wiring diagram.
    I know in the Mon 7's it is around 6.2 ohm.
    IDK what it would be in a RTA 11, since there is not a "Peerless" version of those.
    I have not personally compared the Peerless to other tweets yet, but 'I have read' that the RDO's are still better....bu the Peerless would definately be a step up from the SL2000's....
    great find... :)
  • danz1906
    danz1906 Posts: 5,144
    edited October 2009
    zippty2001 wrote: »
    Congrats on the Good find!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    heiney9 Posts: 25,440
    edited October 2009
    zarrdoss wrote: »
    They aren't interchangeable with the sl2000. The x-over is different. The RD0 is slightly larger than the peerless so some wood working with a dremel on the tweeter opening would be nec on the Monitor 5's.
    As far as the 11T, just get the RD0194-1 if you have sl2000's and are looking for replacement tweeter that sounds a thousand times better.
  • skrol
    skrol Posts: 3,452
    edited October 2009
    Also, the Monitor 5 (Peerless) XO's vary. While some have the 6.2 ohm, mine have 2.5 ohm (built in 1983). I have been working with Polk CS to try to figure which would be better.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • zippty2001
    edited October 2009
    skrol wrote: »
    hay skrol i sent you a pm the other day about about your rta upgrades. can you give me some info please on what you used for the xover and stuff. i want to start on mine soon and i am looking for info on what to do thanks allot.
  • danger boy
    danger boy Posts: 15,722
    edited October 2009
    are those monitor 5's?
    PolkFest 2012, who's going>?
    edited October 2009
    danger boy wrote: »
    Yes, very early Monitor 5's as evidenced by the drivers, cabinet, grill attaching method and double fuses.
  • skrol
    skrol Posts: 3,452
    edited October 2009
    zippty2001 wrote: »
    I just sent the PM
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • ben62670
    edited October 2009
    heiney9 wrote: »
    Amen. Why hack an excellent speaker, and kill a true classic.
    Don't blow those tweeters!
    Ben
  • skrol
    skrol Posts: 3,452
    edited October 2009
    I love how thick the top, bottom and sides of the cabinet are. My Monitor 5A's are rock solid but they are not that thick.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • zippty2001
    edited October 2009
    skrol wrote: »
    ya they are heavy i would guess 15 - 20 pounds a speaker i might be wrong
    thanks for the help skrol i am not going to do any thing to the m5s i might sell them to help me with my rta 11 upgrades but i don't know yet the cabinets are in OK shape they have a lot a ware and tare but for how old they are they are in good shape...
