Sony bdp-s2000es won"t play any disc's
duggy
duggy Posts: 10
edited October 2009 in Electronics
Can anyone tell me where I can get a BDP-100 drive that's in my Sony BDP-S2000ES blu ray player?
It's slowly stopped playing disc's,blu and or CD disc's.
By the way,I can't do a firmware update either ,because it won't play or read those either.
Post edited by duggy on
  • Sherardp
    Sherardp Posts: 8,038
    edited October 2009
    ES machines carry a 5yr warranty so I would send it in for service. Contact Sony and go from there. I would not buy a single part if the machine is under warranty for 5 yrs. See warranty card here
    http://esupport.sony.com/US/perl/model-documents.pl?mdl=BDP-S2000ES&region_id=1
  • duggy
    duggy Posts: 10
    edited October 2009
    Sherardp wrote: »
    That does'nt help.Do you know the Sony part number for the blu ray drive? For the Sony BDP-S2000ES blu ray player?
  • danz1906
    danz1906 Posts: 5,144
    edited October 2009
    duggy wrote: »
    Welcome to the Club!
    Call Sony for the part number, but if it still under Warranty just send
    it back to Sony!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • BlueFox
    BlueFox Posts: 15,251
    edited October 2009
    duggy wrote: »
    What is wrong with warranty work? Did you steal it? :rolleyes:
    Kidding aside. I had a Sony 3100ES DVD player break after 1 month. I sent it into to Sony for repair, and they would not honor the warranty. They said I had done an unauthorized repair on it, which was BS. I bought it new from Crutchfield, but there was no way I could convince them of that. Anyway, Crutchfield replaced it after I explained what was happening, but I always wondered if Crutchfield would have been so nice if 4 years had gone by before it broke.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited October 2009
    I think they would have. I had a $600 JVC VCR I bought from Crutchfield that came with a two year warranty. I had it repaired twice under warranty the second year, sent it in to Crutchfield and they took care of it both times. It then broke again just out of warranty. Crutchfield gave me a full refund in the form of a store credit.
  • lukewayne
    lukewayne Posts: 80
    edited October 2009
    I had a sony ES receiver that had issues, they gave me an advance exchange under warranty, the second time i needed a switch they upgraded me to the next model year. their ES warranty is pretty good, although you might have to be persistent on the phone and try to talk to level 2 or 3 support.
    if the player has an ethernet port, consider direct download fw update, thats how i update my bdp-350
    ________________________________
    Panasonic TH-50PZ800U; Sony BDP-S350
    Sony STR-DA5400ES; Carver TFM-55
    Carver TFM-35; Carver A-500x
    Sony Playstation 3; Custom HTPC
    Polk Monitor 10B Front; 2xPolk CS350LS Center;
    Monitor 5B rears (RB0194-1 Upgrade);
    Velodyne VA1012XII sub
