Fxi30 Setup
DannyV
DannyV Posts: 23
edited September 2003 in Speakers
ok,
I just got these fxi30's setup and I have a question on putting out better sound from them.
I have them set to dipole because they are the rears in a 5.1 setup.
I have my speakers set to large and distance from rears set to 6 feet.
I'd like to hear more sound to come from the rear channels. It feels like alot more sound is coming from the front channels.
How do I do this with no Fade control ??
Danny V
57" toshiba cinema series
H/K 525
"pos" Panasonic DVD progressive scan
Front: Polk Rti1000p
Center: Polk Csi40
Rear: Polk Fxi30
Sub: Velodyne CHT-10
Post edited by DannyV on
  • Emlyn
    Emlyn Posts: 4,888
    If they're behind you, switch the switch to bipole and adjust the surround level up for each speaker using an SPL meter. I set mine about 2 decibels higher than the front. Your needs may vary. Experiment.
  • jkratzer
    jkratzer Posts: 148
    I agree that the only way you can set the FXi30's up properly is with an SPL meter. It can't really be done right by ear. I use the Radio Shack digital model with the S&V tuneup disc tuned to 75 db. Mine are also set to bipole because they are behind me.
    My 7.1 setup consists of:
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RTi28s side surround
    FXi30s back surround
    PSW202 Subwoofer - Hey, it's my first sub!
    RCA 46" 4:3 RPTV
  • dorokusai
    dorokusai Posts: 25,627
    I agree, set them to Bipole, and listen again. If they sound better, no changes.
    I also bumped my rear levels up +2db, because thats the way I liked it the best.
