LSi 15 and Jolida 202A
chargerman426
I'm looking at getting a Jolida 202A for my LSi 15's. This would be my first tube amp. Right now I'm running a Carver C-4000 and a M 1.0T that have been redone by Bob lest then a year ago. My qustion is are the 40 watts the 202A puts out enof for my LSi's? I know that one tube watt is like 2 SS watt but still that is only 80 watts. Thank you for your help.
If life had more tubes it would be a lot smoother.
Post edited by chargerman426 on
IMO, the LSi line need SS amplification. I have tried tube amps on my LSi and they only sound good at very low levels. Once you turn it up, they can't control those woofers.
Why not try a tube pre amp with your Carver amps? -
The reason I'm getting the jolida is that my friend is getting rid of it so I was going to get it cheeper.If life had more tubes it would be a lot smoother.
I'm interested in knowing if a tube amp would mate well with the LSi-15's, I am toying with idea of jumping into tubes.
Jimmy -
As long as you don't use the 15's for HT or listen at concert levels, that Jolida or a comparable tube amp should work fine. They only dip down to 3ohms, so they're an easier load than LSi9's.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Very nice setup, Face! is that the X/O on the floor behind the 15? I take it you have no kid nor pet?
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Yes, the x-over for another speaker.Very nice setup, Face! is that the X/O on the floor behind the 15? I take it you have no kid nor pet?
No kids and the pets have their own bedroom.
I'm going to listen to the jolida tomarrow on my LSis and if I like it then I will pick it up. I have never listen to a tube amp on any equipment I know so I'm not sure if I will notice a difference from my carvers.If life had more tubes it would be a lot smoother.
Whoa!!!:eek: Awesome set up. That's interesting. I had no idea the 15's min was 3ohms. I had mine on the 9's.
Are you using the 8 or 4 ohm output taps? -
The Stingray only has one pair of outputs and it's optimized for 5ohm speakers."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
aaaah cool:cool: That set up must sound sweet.
So I bought the amp and I'm loving every minute with it. I liked the warmth it added to the LSi's. The bass was a bit light so I tool the psw404s I was using on the HT and they sound amazing! Wish I had bought some tube stuff a long time ago. Can't wait to try some differnt tubes so I can see if I can tell a differce.If life had more tubes it would be a lot smoother.
what power tubes does the 202a use?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Great job enjoy
So i rolled some tubes a few weeks ago. I tried some EH 6CA7's and some JJ 12ax7 and at7. i felt the 6CA7s made the amp really bright. I didnt like it so i put the EL24's back in. As for the JJ's they were ok but i liked the old Hallicrafer USA tubes they are in it better so put them back in to.If life had more tubes it would be a lot smoother.
