Female IEC Inlets
inspiredsports
I'm currently upgrading power supplies, cords, etc. and inherited a box of parts with several female IEC inlets from a friend who used to repair televisions and computer monitors .
There are 2 medium quality 15A inlets marked "Yamate AP-300" that have wires attached (easily removable as they are connected with terminals).
The wires are run through a metal ring (a magnet will stick to it) as shown in the image below.
What is the purpose of the metal ring?
I plan on re-using these in non-critical components and wonder if I should remove the ring or if there is a benefit to using it.
Aso, I've heard great things about Furutech Nylon IEC Inlets with Cryogenic Rhodium Plated Bronze contacts for highline applications. Are there other recommended IEC female connectors members have had good luck with?
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
NAD SS rigs w/mods
GIK panels
Post edited by inspiredsports on
Do you want warm sounding or a little tipped up.Check out IeGO IEC inlets.I would go with the silver but damn there expensive.The gold plated copper ones are easy on the wallet.
Link>>http://www.acoustic-fun.com/catalog/product_info.php?products_id=55SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
That ring is too reduce any EFI noise from the AC.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
IIRC it is a ferrite core which keep's the cord from becoming an "antenna"
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
sTiLlLeArNiNg wrote: »IIRC it is a ferrite core which keep's the cord from becoming an "antenna"
disneyjoe7 wrote: »That ring is too reduce any EFI noise from the AC.
So would there be any benefit to using this configuration in a CD player, etc.?VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels
