Female IEC Inlets
inspiredsports
inspiredsports Posts: 5,502
edited October 2009 in Electronics
I'm currently upgrading power supplies, cords, etc. and inherited a box of parts with several female IEC inlets from a friend who used to repair televisions and computer monitors .
There are 2 medium quality 15A inlets marked "Yamate AP-300" that have wires attached (easily removable as they are connected with terminals).
The wires are run through a metal ring (a magnet will stick to it) as shown in the image below.
What is the purpose of the metal ring?
I plan on re-using these in non-critical components and wonder if I should remove the ring or if there is a benefit to using it.
Aso, I've heard great things about Furutech Nylon IEC Inlets with Cryogenic Rhodium Plated Bronze contacts for highline applications. Are there other recommended IEC female connectors members have had good luck with?
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
Post edited by inspiredsports on
  • fbm211
    fbm211 Posts: 1,488
    edited October 2009
    Do you want warm sounding or a little tipped up.Check out IeGO IEC inlets.I would go with the silver but damn there expensive.The gold plated copper ones are easy on the wallet.
    Link>>http://www.acoustic-fun.com/catalog/product_info.php?products_id=55
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2009
    That ring is too reduce any EFI noise from the AC.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    IIRC it is a ferrite core which keep's the cord from becoming an "antenna" :confused:
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • inspiredsports
    edited October 2009
    disneyjoe7 wrote: »
    So would there be any benefit to using this configuration in a CD player, etc.?
    NAD SS rigs w/mods
    GIK panels
