A Supercharger for your Amp?
nooshinjohn
nooshinjohn Posts: 25,925
edited November 2009 in Electronics
I have never heard of such a thing, but appearantly, you add this thing between your amp and your speakers and it boosts the output to 550wpc, and uses speaker wire for the connections. Could this be a viable solution for those that do not have pre-outs on their receivers?
Personally I would choose to go another route, but thought the producr was intriguing enough to start a conversation about it...
http://www.musicdirect.com/product/81862
Post edited by nooshinjohn on
  • Systems
    Systems Posts: 14,873
    edited October 2009
    It's just a power amp with special hi level inputs that allow it to accept the input from another amp.It also has the usual (low leve)l pre inputs.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited October 2009
  • Paden501
    Paden501 Posts: 286
    edited October 2009
    This reminds me of car audio amps. A lot of them also have 'line level' converters built in, so that you can plug your factory rear channel speaker wire into the amp instead of running pre-amp RCA cables all the way back through your car.
    ~Matt
    My System
    Front L/R: Definitive BP10Bs
    Surrounds -Polk Audio Monitor 4As
    Preamp: B&K Reference 20
    CD: Jolida JD100a
    L/R Amp: Carver TFM-24
    Turntable: Pioneer PL-516 W/ Shure M97xe
    TV: Sony 52" XBR9
  • Systems
    edited October 2009
    Paden501 wrote: »
    This reminds me of car audio amps. A lot of them also have 'line level' converters built in.
    Exactly.
    Testing
    Testing
    Testing
    edited October 2009
    Kex wrote: »
    ... Hmmm ... at $1,000 per speaker, for a demo unit ($2,500 otherwise), that would be an expensive upgrade for any receiver that is an entry level model (since it has no pre-outs). It would be a whole lot cheaper just to buy a new receiver for less than $500 (there are lots of choices nowadays for that price), sell the old one for $100, and get a regular amplifier.
    I'm not quite sure what the intended market is for this device. Can you imagine buying five, or even seven?
    +1... I am not by any means saying they are a viable product for 95% of us, only that they were interesting.;)
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited October 2009
    Kex wrote: »
    Well if you don't like demo's, Audio Advisor has been selling these for $1250 new for a long time now. I don't think they were a hot seller.
    http://www.audioadvisor.com/prodinfo.asp?number=MF550K%20%20%20%20E
  • Systems
    edited October 2009
    WilliamM2 wrote: »
    I think in part because of the way in which MF marketed it as a" supercharger" and not just a poweramp.I think some were confused as to its purpose and purists likely shun the "booster amp" concept prefering the standard pre approach. Used in regular fashion driven by a preamp, it may well be a good sounding amp.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited October 2009
    GV#27 wrote: »
    I think in part because of the way in which MF marketed it as a" booster amp" and not as a poweramp.I think some were confused as to its purpose.
    Or thought they sounded "gimmicky".
  • phuz
    phuz Posts: 2,372
    edited October 2009
    I got heat for this when this was discussed before but I thought they were a cool idea. Limited demographic, but cool. Want to mate those sweet sounding 10 watt tube monoblocks up with some Dynaudio Evidence Temptations? These make that possible.
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2009
    The most ridiculous product MF has ever made.
  • Krazyz1
    Krazyz1 Posts: 256
    Sounds like a EXPENSIVE twist to a Carver M-400
  • madmax
    madmax Posts: 12,434
    It is a great idea, you guys just don't get it. It preserves the sonic character of an audiophile quality flea powered amp while allowing use of low efficiency speakers. Avantgarde utilizes the same philosophy to power the woofers in their horn speakers, otherwise they would have to use really big enclosures.
    madmax
    Vinyl, the final frontier...
