A Supercharger for your Amp?
nooshinjohn
I have never heard of such a thing, but appearantly, you add this thing between your amp and your speakers and it boosts the output to 550wpc, and uses speaker wire for the connections. Could this be a viable solution for those that do not have pre-outs on their receivers?
Personally I would choose to go another route, but thought the producr was intriguing enough to start a conversation about it...
http://www.musicdirect.com/product/81862
Post edited by nooshinjohn on
It's just a power amp with special hi level inputs that allow it to accept the input from another amp.It also has the usual (low leve)l pre inputs.Testing
Testing
Testing -
They're over rated: http://www.polkaudio.com/forums/showthread.php?p=997294&highlight=supercharger#post997294"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
This reminds me of car audio amps. A lot of them also have 'line level' converters built in, so that you can plug your factory rear channel speaker wire into the amp instead of running pre-amp RCA cables all the way back through your car.~Matt
My System
Front L/R: Definitive BP10Bs
Surrounds -Polk Audio Monitor 4As
Preamp: B&K Reference 20
CD: Jolida JD100a
L/R Amp: Carver TFM-24
Turntable: Pioneer PL-516 W/ Shure M97xe
TV: Sony 52" XBR9 -
Exactly.This reminds me of car audio amps. A lot of them also have 'line level' converters built in.Testing
Testing
Testing -
... Hmmm ... at $1,000 per speaker, for a demo unit ($2,500 otherwise), that would be an expensive upgrade for any receiver that is an entry level model (since it has no pre-outs). It would be a whole lot cheaper just to buy a new receiver for less than $500 (there are lots of choices nowadays for that price), sell the old one for $100, and get a regular amplifier.
I'm not quite sure what the intended market is for this device. Can you imagine buying five, or even seven?
+1... I am not by any means saying they are a viable product for 95% of us, only that they were interesting.;)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Well if you don't like demo's, Audio Advisor has been selling these for $1250 new for a long time now. I don't think they were a hot seller.
http://www.audioadvisor.com/prodinfo.asp?number=MF550K%20%20%20%20E -
I think in part because of the way in which MF marketed it as a" supercharger" and not just a poweramp.I think some were confused as to its purpose and purists likely shun the "booster amp" concept prefering the standard pre approach. Used in regular fashion driven by a preamp, it may well be a good sounding amp.Testing
Testing
Testing -
Or thought they sounded "gimmicky".I think in part because of the way in which MF marketed it as a" booster amp" and not as a poweramp.I think some were confused as to its purpose."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I got heat for this when this was discussed before but I thought they were a cool idea. Limited demographic, but cool. Want to mate those sweet sounding 10 watt tube monoblocks up with some Dynaudio Evidence Temptations? These make that possible.
The most ridiculous product MF has ever made.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Sounds like a EXPENSIVE twist to a Carver M-400
It is a great idea, you guys just don't get it. It preserves the sonic character of an audiophile quality flea powered amp while allowing use of low efficiency speakers. Avantgarde utilizes the same philosophy to power the woofers in their horn speakers, otherwise they would have to use really big enclosures.
