Bi Amping
Any links to bi-amping out there.I can not seem to find anything of use.I need a step to step guide .
Post edited by opus007 on
go to wiring....- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
There are a couple of different varieties. If you do a Google search or even a forum search you will find some good how to info.
Are you wanting to use a separate amp for each speaker OR 1 amp for the highs on each speaker and another for the lows on each?
I want to use seperate amps for high and low and am just starting to understand this.My amp Sony Str-de845 does not have a pre -amp out.What would be the best amp to get to bi-amp using RT-800i mains.
Now that's an Electronics section question... (kidding)
Are you strickly a 2-ch guy, or looking for HT? What's your budget? Are you open to used Equipment?More later,
Tour...
Vox Copuli
