Bi Amping
opus007
opus007 Posts: 17
edited September 2003 in Speakers
Any links to bi-amping out there.I can not seem to find anything of use.I need a step to step guide .
Post edited by opus007 on
    VR3 Posts: 29,662
    go to wiring....
  • TroyD
    TroyD Posts: 13,124
    There are a couple of different varieties. If you do a Google search or even a forum search you will find some good how to info.
    Are you wanting to use a separate amp for each speaker OR 1 amp for the highs on each speaker and another for the lows on each?
    BDT
  • opus007
    opus007 Posts: 17
    I want to use seperate amps for high and low and am just starting to understand this.My amp Sony Str-de845 does not have a pre -amp out.What would be the best amp to get to bi-amp using RT-800i mains.
  • Tour2ma
    Tour2ma Posts: 10,177
    Now that's an Electronics section question... (kidding)
    Are you strickly a 2-ch guy, or looking for HT? What's your budget? Are you open to used Equipment?
    More later,
    Tour...
    Vox Copuli
