hafler dh500 and sda2b
PW47
PW47 Posts: 76
edited October 2009 in 2 Channel Audio
hy ineed help ! ihave the hafler dh500 with iuse with my sda2 b but mostly the time is cutting when irise the volume up ,above quarter ,now also is switchlight is flashing . any tec ? to fix it . thanks . also another question,about the dsa2b maybe ilike to upgrade the tweeters dome to rdo 198 ! but ..... is necessary to work in my crossover ? ilike the way my sda2b sounds ,so like to keep as much close to the original . one thing is to upgd the tweeters ,another is to change the original project .
Post edited by PW47 on
    nooshinjohn Posts: 25,974
    edited September 2009
    what?... I would love to offer some help here, but I am having trouble understanding your post
  • PW47
    PW47 Posts: 76
  • NJPOLKER
    NJPOLKER Posts: 3,475
    PW47 wrote: »
    And I thought I drink a lot :confused:
  • PW47
    PW47 Posts: 76
  • PW47
    PW47 Posts: 76
    dont drink and drive daddy !
  • NJPOLKER
    PW47 wrote: »
    After making a cocktail I got it, some of it anyway.
    The RDO -194 or RDO-198 will be a drop in replacement. You have to figure out which tweeters are in there now. You don't "need" to change the x-overs to replace the tweeters. Pictures will help us help you. Maybe one of the peeps here knows if the Hafler is common ground, all power sources need to be common ground when running SDA's.
  • PW47
    PW47 Posts: 76
    ok my question is if is possible to change the dome tweeters for the upgrade rdo198 withouth touch in thr crossover ? thanks :confused:
  • PW47
    PW47 Posts: 76
    NJPOLKER wrote: »
    well thanks , ok iwill place some picture ibelieve the tweeter are black dome , and how can ifind out thoses rdo 198 ? do you believe is one step ahead ? thanks , yes man ibeen drink a bit ,but istop now .;)
  • NJPOLKER
    Where the hell are you from?
    I've been known to have a few but after trying to read your posts I gotta say WOW whatever you drink is some good **** :rolleyes::eek::cool:
  • NJPOLKER
    I just can't wait to see the pictures.
  • fbm211
    fbm211 Posts: 1,488
    Pull out a tweeter and read the back.Model # will be on it. You have to mod the xover to use the 198s by bypassing the resistor with a custom value 5.8uf cap you can order at soniccraft.
    If there is something wrong with your amp you can call musical concepts-musical design and talk to john.He can fix those amps.>>http://www.musicaldesign.com/
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • comfortablycurt
    comfortablycurt Posts: 6,745
    The RD0-194's are the direct replacement for the 2B's. Upgrading to the 198's will require a crossover modification.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • ESavinon
    ESavinon Posts: 3,067
    The Hafler DH-500 is a common ground amp.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • ohskigod
    ohskigod Posts: 6,505
    check the fuses, I believe the power level of the amp changes depending on the fuse....I believe the ma in 10 amp? but dont quote me, I'll check one of mine to look as I know I put in the biggest size when I them them (I have 2). Great amps in my eyes that sometimes dont seem to get the love they deserve.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • rmaiers
    rmaiers Posts: 145
    edited October 2009
    I am currently running my SDA-2Bs with a Hafler DH-500. If he is blowing a polyswitch at relatively low volume settings he may need to check the DC offset in the output channels.
    I had a similar problem (poly switch opening on one channel at about 11:00 on the volume). I was also blowing the tweeter protection fuse in the same channel at about 11:00 when running my RTA-12Bs with the Hafler. The only advice I got from this forum was the Hafler was clipping at that level which I found very hard to believe given the Hafler's specs.
    I learned about output channel DC offset issues in Hafler DH-500s from another forum.
  • rmaiers
    rmaiers Posts: 145
    edited October 2009
    Audiokarma.org has a lot of info. on the Hafler DH-500. This is where I got the info. about DC offset checks.
  • PW47
    PW47 Posts: 76
    edited October 2009
    hy rmaiers . thanks for the info . did you fix the problem ? regards pw
  • PW47
    PW47 Posts: 76
    edited October 2009
    NJPOLKER wrote: »
    SOME REDNECK STAFF YO DONT WANT TO KNOW . MUDDYWATER STAFF ,MOONSHINE . THANKS FOR THE INFO . IWILL CHECK THE TWEETER . IAM ITALIAN SELF MADE . SO IREALIZE THE DIFICULTIES OF CHAMPOLLION. HAVE GOOD ONE .:rolleyes:
  • PW47
    PW47 Posts: 76
    edited October 2009
    the rd0-194's are the direct replacement for the 2b's. Upgrading to the 198's will require a crossover modification.
    thanks , rdo 194 is the direct replacement ,so ican change and no modification in the crossover . By change the original black dome by 194 is substancial upgrade ?
  • PW47
    PW47 Posts: 76
    edited October 2009
    fbm211 wrote: »
    pull out a tweeter and read the back.model # will be on it. You have to mod the xover to use the 198s by bypassing the resistor with a custom value 5.8uf cap you can order at soniccraft.
    If there is something wrong with your amp you can call musical concepts-musical design and talk to john.he can fix those amps.>>http://www.musicaldesign.com/
    thanks a lot iwill call john h . Pw
  • rmaiers
    rmaiers Posts: 145
    edited October 2009
    Not yet. There is no DC offset adjustment on the Hafler so I need to get a matched set of transistors and replace. I can still use the system as long as I stay below 11:00 on the volume.
  • PW47
    PW47 Posts: 76
    edited October 2009
    rmaiers wrote: »
    icall mr j.hiling : he will be able to fix it ! he mention ! its an common defect after all this time ! in my case is overheating ,so the protection circuit is cutting ! thermal issues in the bottom of the amp . irather send it to the master . regards pw .
  • danger boy
    danger boy Posts: 15,722
    edited October 2009
    that's good that you know what's causing the problem.. amps can have problems after they get up in age.
    PolkFest 2012, who's going>?
