Sda srs 1.2 1.2tl
restanim
restanim Posts: 227
edited September 2009 in Vintage Speakers
I am considering on buying these speakers. I am not near them, nor do I have a picture of back panel. What model do you think they are?
You need Adobe Reader to view.
Doc1.pdf
What Model Are These.pdf
another.pdf
Thanks,
Mike
polkaudio
Currently Own:
RTA-11T Light Oak, Aug/2011 to present
SDA-CRS+ Aug/2011 to present
RTA-11T Black, Dec/2013 to present
Previously Owned:
SDA-SRS 2.3 May/1990 to June/1991
SRS 1.2TL June/1991 to May/1995
SDA-1C Aug/2005 to Dec/2011
SRS 1.2TL Sept/2009 to Sept/2015
Post edited by restanim on
    nooshinjohn Posts: 25,883
    TL's no doubt... where did you find them?
  • restanim
    restanim Posts: 227
    I asked if they were 1.2TL's and the owner claims they are 1.2's. No mention of TL. So I look closer and I see that the tweeters may be RDO's.
    What do you think?
    MIke
    polkaudio
    Currently Own:
    Previously Owned:
  • bdaley6509
    bdaley6509 Posts: 1,167
    Nope...SL3000's by the pics.
  • ben62670
    ben62670 Posts: 15,969
    Black SL3000's That is new to me. They may just look black in the pics? They look like RDO's. If the seller can pull one of the tweeters you will know for sure. Also a model number would be nice.
    Ben
  • leroyjr1
    leroyjr1 Posts: 8,785
    Definately SL3000's
  • ben62670
    That's cool. Then they are 1.2TL's.
    Ben
    F1nut Posts: 51,686
    They could be 1.2TL's with a 1.2 label, but they could be 1.2's that either had the TL upgrade done or simply had the SL2000's replaced with SL3000's. A look at the crossover will tell you more.
  • Hamatym
    Hamatym Posts: 269
    Restanim,
    Just curious what kind of a price range you are getting them for. I am going back and forth on whether or not I want to try and sell my 1.2TL's....just curious, no worries if you don't feel comfortable posting that info.
  • vijayl
    vijayl Posts: 258
    Lasareath wrote: »
    Maybe you should post it, it looks like this could be your destiny as both of you have exactly 54 posts each!
    :cool: comment
    Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
    , logitech 880
    Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
    2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
    Bed Room: Pioneer Elite VSX-52 , Monitor 50
    Storage-RTi8,CSi5,PSW505,Monitor50
  • restanim
    restanim Posts: 227
    I got a picture of the rear panels. They both read SRS 1.2 6XXX. The binding posts are of the bi-amp style with a jumper wire between them. The inter connect is pin/blade. The asking price is $1250.
    Mike
    polkaudio
    Currently Own:
    Previously Owned:
    F1nut Posts: 51,686
    restanim wrote: »
    Mike
    Everything I stated in my post above still applies.
  • restanim
    restanim Posts: 227
    I just got a message from the seller and he states that he does not have the interconnect cable :(
    What should I do?
    I do have a cable from my 1C's.
    polkaudio
    Currently Own:
    Previously Owned:
  • ben62670
    I make real nice custom SDA IC's cheap. Your 1C IC will work if it is pin blade.
    Not a problem.
    Ben
    Ben
  • restanim
    restanim Posts: 227
    My distance to them is about 375 miles. WOW! 6 hour drive one way. Will they fit in a Dodge Grand Caravan with the seats folded down (Stow-N-Go)? I hope so.
    Should I talk down the price because the interconnect cable is missing? If so, how much?
    Mike
    polkaudio
    Currently Own:
    Previously Owned:
  • leroyjr1
    restanim wrote: »
    Mike
    $1250 is a steal with or with out the cable. Worse case use bare wire to get you by. Not a big deal.
  • vmaxer
    vmaxer Posts: 5,120
    restanim wrote: »
    Mike
    Yes they will fit your van, most people here say to haul them on their back...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Big Dawg
    Big Dawg Posts: 2,005
    vmaxer wrote: »
    Actually, I believe that most people recommend that they be transported on their front if the drivers aren't removed, to protect the magnets. Someone else please verify.
  • Hamatym
    Hamatym Posts: 269
    Hauling on their faces makes sense, but I found it extremely hard to slide them like that because they weigh so much. I always feared the cloth ripping as you slide them into your vehicle (even with a ton of blankets and protection). I hauled theses same speakers a couple times on their backs in a nice enclosed Expedition and NEVER had any issues. Again, my ride is pretty smooth so it really worked well. It always depends how flat they are in your vehicle. Those are my thoughts of the day
  • bluecomet
    bluecomet Posts: 1,118
    When I bought my SDA SRS and SDA SRS 1.2's I used a Susuki XL7. One speaker was on it's back and the other sideways. It was the only way they would fit. I had no problems in either case. I would brake down some boxes and lay them down under the speakers. It makes it much easier to slide them in and out. I then used a funiture dolly by myself. They are big and heavy but if you take your time you can do it by yourself if you don't have any steps. If steps are involved you will need another person to help you lift them and steer them if you have a hand truck. That's a good price for those speakers if you don't mind the 6 hour ride one way. Good luck.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
    Big Dawg wrote: »
    This is certainly the wrong way to go as this damages the domes on the tweeters.:eek:
    F1nut Posts: 51,686
    No one here, let me repeat, no one here has ever recommended that SDA's be transported on their face. In fact, it defies all logic.
    Toolfan66 Posts: 17,991
    Agreed!!!! I hauled mine on their back with moving blankets, and pulled the PR's out.
  • leroyjr1
    I've transported over 12 pairs of SDA's in my car/truck with them on there back without any issues.
  • leroyjr1
    Why did you pull the passive out? To see if the magnet fell off?:p
  • polksda
    polksda Posts: 716
    leroyjr1 wrote: »
    Ok, now that one made me laugh out loud. Well played, sir!
  • restanim
    restanim Posts: 227
    Well fella's,
    I got them home today and they look fantastick!
    The label in the back reads SRS 1.2 L/R 61XX
    They have the SL3000 tweeters which indicate they should be TL's.
    I just need to check the crossovers to see actally what they are.
    I don't know how to tell what crossovers I have. Help?
    I have not hooked them up yet, cleaning is first.
    Mke
    polkaudio
    Currently Own:
    Previously Owned:
  • NJPOLKER
    NJPOLKER Posts: 3,474
    Take pictures of the crossovers and post them. The fellows around here will be a big help. Congratulations on a great pair of speakers.
    F1nut Posts: 51,686
    The crossovers will have an ID sticker on them indicating the model.
  • vmaxer
    vmaxer Posts: 5,120
    Good luck with them, I love mine. Keep us posted.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • restanim
    restanim Posts: 227
    The ID sticker reads:
    SRS 1.2
    BE2000-C
    2/8/89 4
    Mike
    polkaudio
    Currently Own:
    Previously Owned:
