Sda srs 1.2 1.2tl
restanim
I am considering on buying these speakers. I am not near them, nor do I have a picture of back panel. What model do you think they are?
You need Adobe Reader to view.
Doc1.pdf
What Model Are These.pdf
another.pdf
Thanks,
Mike
Doc1.pdf
another.pdf
Thanks,
Mike
polkaudio
Currently Own:
RTA-11T Light Oak, Aug/2011 to present
SDA-CRS+ Aug/2011 to present
RTA-11T Black, Dec/2013 to present
Previously Owned:
SDA-SRS 2.3 May/1990 to June/1991
SRS 1.2TL June/1991 to May/1995
SDA-1C Aug/2005 to Dec/2011
SRS 1.2TL Sept/2009 to Sept/2015
Currently Own:
Previously Owned:
Post edited by restanim on
TL's no doubt... where did you find them?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I asked if they were 1.2TL's and the owner claims they are 1.2's. No mention of TL. So I look closer and I see that the tweeters may be RDO's.
What do you think?
MIkepolkaudio
Currently Own:
Previously Owned:
SRS 1.2TL Sept/2009 to Sept/2015 -
Nope...SL3000's by the pics.
Black SL3000's That is new to me. They may just look black in the pics? They look like RDO's. If the seller can pull one of the tweeters you will know for sure. Also a model number would be nice.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Definately SL3000's
That's cool. Then they are 1.2TL's.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
They could be 1.2TL's with a 1.2 label, but they could be 1.2's that either had the TL upgrade done or simply had the SL2000's replaced with SL3000's. A look at the crossover will tell you more.Political Correctness'.........defined
President of Club Polk -
Restanim,
Just curious what kind of a price range you are getting them for. I am going back and forth on whether or not I want to try and sell my 1.2TL's....just curious, no worries if you don't feel comfortable posting that info. -
Maybe you should post it, it looks like this could be your destiny as both of you have exactly 54 posts each!
:cool: comment
Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07, logitech 880
Def Tech Mythos ST
Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
Bed Room: Pioneer Elite VSX-52 , Monitor 50
Storage-RTi8,CSi5,PSW505,Monitor50 -
I got a picture of the rear panels. They both read SRS 1.2 6XXX. The binding posts are of the bi-amp style with a jumper wire between them. The inter connect is pin/blade. The asking price is $1250.
Mikepolkaudio
Currently Own:
Previously Owned:
Mike
Everything I stated in my post above still applies.Political Correctness'.........defined
I just got a message from the seller and he states that he does not have the interconnect cable
What should I do?
I do have a cable from my 1C's.polkaudio
Currently Own:
Previously Owned:
I make real nice custom SDA IC's cheap. Your 1C IC will work if it is pin blade.
Not a problem.
Ben -
My distance to them is about 375 miles. WOW! 6 hour drive one way. Will they fit in a Dodge Grand Caravan with the seats folded down (Stow-N-Go)? I hope so.
Should I talk down the price because the interconnect cable is missing? If so, how much?
Mikepolkaudio
Currently Own:
Previously Owned:
Mike
$1250 is a steal with or with out the cable. Worse case use bare wire to get you by. Not a big deal. -
Mike
Yes they will fit your van, most people here say to haul them on their back...Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Actually, I believe that most people recommend that they be transported on their front if the drivers aren't removed, to protect the magnets. Someone else please verify. -
Hauling on their faces makes sense, but I found it extremely hard to slide them like that because they weigh so much. I always feared the cloth ripping as you slide them into your vehicle (even with a ton of blankets and protection). I hauled theses same speakers a couple times on their backs in a nice enclosed Expedition and NEVER had any issues. Again, my ride is pretty smooth so it really worked well. It always depends how flat they are in your vehicle. Those are my thoughts of the day
When I bought my SDA SRS and SDA SRS 1.2's I used a Susuki XL7. One speaker was on it's back and the other sideways. It was the only way they would fit. I had no problems in either case. I would brake down some boxes and lay them down under the speakers. It makes it much easier to slide them in and out. I then used a funiture dolly by myself. They are big and heavy but if you take your time you can do it by yourself if you don't have any steps. If steps are involved you will need another person to help you lift them and steer them if you have a hand truck. That's a good price for those speakers if you don't mind the 6 hour ride one way. Good luck.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
This is certainly the wrong way to go as this damages the domes on the tweeters.:eek:Actually, I believe that most people recommend that they be transported on their front if the drivers aren't removed, to protect the magnets. Someone else please verify.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
No one here, let me repeat, no one here has ever recommended that SDA's be transported on their face. In fact, it defies all logic.Political Correctness'.........defined
Agreed!!!! I hauled mine on their back with moving blankets, and pulled the PR's out. -
I've transported over 12 pairs of SDA's in my car/truck with them on there back without any issues.
TOOLFORLIFEFAN wrote: »Agreed!!!! I hauled mine on their back with moving blankets, and pulled the PR's out.
Why did you pull the passive out? To see if the magnet fell off?:p -
Ok, now that one made me laugh out loud. Well played, sir! -
Well fella's,
I got them home today and they look fantastick!
The label in the back reads SRS 1.2 L/R 61XX
They have the SL3000 tweeters which indicate they should be TL's.
I just need to check the crossovers to see actally what they are.
I don't know how to tell what crossovers I have. Help?
I have not hooked them up yet, cleaning is first.
Mkepolkaudio
Currently Own:
Previously Owned:
Take pictures of the crossovers and post them. The fellows around here will be a big help. Congratulations on a great pair of speakers.
The crossovers will have an ID sticker on them indicating the model.Political Correctness'.........defined
Good luck with them, I love mine. Keep us posted.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
The ID sticker reads:
SRS 1.2
BE2000-C
2/8/89 4
Mikepolkaudio
Currently Own:
Previously Owned:
