APC H10Blk Power Conditioner w/Groneberg PC
  • inspiredsports
    inspiredsports Posts: 5,502
    edited September 2009
    I think you are right about prior "protection mode" operation of a used unit.
    I've got to believe that voltage spikes "work temper" (for lack of a better phrase) the metal elements used, ultimately diminishing the ability of the unit to protect.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    heiney9 Posts: 25,445
    Voltage spikes won't diminish the life of the unit (unless they are extreme). Hard lightening strikes will. MOV's are used to supress things like lightening strikes and those have a limited life cycle. It doesn;t matter if you have a cheap unit or expensive unit that uses MOV's as a supressor. Some of the really pricey units use something other than MOV's as a supressor and many times that's why they are 2-3X the cost. MOV's are prefectly acceptable........it's just after a couple direct hits they loose effectiveness and need to be replaced.
    Still for me, during an intense storm I unplug the unit........no unit is 100% effective for a direct lightening hit.
    Also another diffrence I like about the H15 is the digital display info. Voltage, Hz, Current draw and % current used vs. what's available in the unit.
  • inspiredsports
    heiney9 wrote: »
    . . . also another diffrence I like about the H15 is the digital display info. Voltage, Hz, Current draw and % current used vs. what's available in the unit.
    Is yours different than image of my H10Blk faceplate as below?
    NAD SS rigs w/mods
    GIK panels
  • mmadden28
    mmadden28 Posts: 4,283
    The H15 has a digital display like in the pic of the Rotel above.
    Edit--Found one online...
    Oh and here is an internal shot:
    ____________________
    Pool: Atrium 60's/45's
  • inspiredsports
    Got it. Thanks.
    NAD SS rigs w/mods
    GIK panels
