LSi9s and Cambridge Audio 840A
VXR8
Hi all,
Looking to set up a separate 2 channel rig and as the Cambridge Audio 840A ( http://www.cambridgeaudio.com/set_territory.php?TID=36&Redirect=/support_products.php?PID=292 ) will provide 200 watts RMS into 4 ohms, thought might not be a bad option. I also could get the 840E and utilise 2 channels from my Emo MPS-2 (300 into 4 ohms), but am really looking for something that can hold it's own, without the need or possible discolouration from an external amp.
Anyone tried this combo at all? Any help would be appreciated.
Thanks in advance.
Thanks in advance.
Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200
Main System
Denon - AVC-4700H
Emotiva - XPA-9
SVS - PB1000 x 2
Foxtel - iQ4
Sony K77A9G
Front Room System
Post edited by VXR8 on
The Cambridge unit should get the job done. I believe someone else here has one, hopefully he'll chime in."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks Face for the reply - any other takers that had this combo or know of it?Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
SVS - PB1000 x 2
Foxtel - iQ4
Sony K77A9G
Front Room System
Polk Audio - Legend L200 -
I haven't had the specific combo, but I have had Cambridge components and listened to Lsi9's for an extended period with the rig in my sig.
I think sonically it'll be a very good match, but Lsi9's are hell on an amp--I'd be careful not to push into clipping. If you like to rock real hard, you might opt for something in the 200WRMS @ 8ohm range; (which would be about 385watts @ 4ohms with a strong amp). Just my personal opinion.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
