Take it off, girls!!!
Cats are simply doing what comes naturally. I had both Tami & Oscar declawed. (front claws only) They never were let outside to roam & lived long, healthy, happy lives & I still have all my furniture & speakers INTACT!!!
Both loved to sharpen their nonexistant claws on my speakers.I have cats. They are not permitted in my music room. There is way too much money in my speakers and my gear. You could always declaw the cat. I know some people are against it but it depends on how you look at it. It is a trade off for a good life in a loving home. Other people will say it is cruel. I have had both kind of cats. The declawed cats had the run of the house, my cats at this point with claws are confind to a couple of rooms. I would be ripping if my cat messed up my SDA SRS 2's or any speaker of mine. Just my opinion.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
They can still mark territory with the scent pads on their paws. Our cat rubs his front paws on my speakers almost daily.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Grills off,looks better.Grills on ,sounds better
I prefer my Audiophysic's topless but when i had my Paradigm ref 100 V3's the grills were mdf framed and tapered beneath the cloth to direct the sound dispersion and it was recommended to use themRogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
Grills off all the time.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I like the look of my speakers with the grills off. I haven't noticed a difference in the sound either way though.
Although with them off I have to watch my nephew like a hawk when he comes over. He's only 2 (almost 3) and he has an obsession with trying to touch my speakers and trying to put things in the ports. Worse though he likes to try and touch my LCD TV...grrrr. -
Welcome to Club Polk Zerba!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Grilles on always, just like my seatbelt!I refuse to argue with idiots, because people can't tell the DIFFERENCE!
Welcome indeed Zerba. I had a pair of Swan speakers that had netting at the end of the ports on the inside. It kept thing from getting stuck in there.
What kind of speakers are you running? -
Usually leave mine on but decided tonight to do some listening tonight with them off.
The highs had more sparkle. Got me to thinking that with the 2000 tweets the grills on would be better but with the RDOs the factory cloth may be too heavy.
I think changing the grill cloth was one of DarqueKnight's recommended upgrades in his improvements for SDA-1Cs threads.
https://shop.polkaudio.com/forums/showthread.php?t=47379Speakers: SDA-1C (most all the goodies)
Vifas naked (.) (.)HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
