new t/t
chemical
i recently purchased a new t/t.....and i am getting back into my old lp's
i know its what my ears hear,but i was just wanting some opinions on what mode to listen to the lp's in.
i have an onkyo 806 and have been using the pure audio mode
is there much difference in the direct mode,i haven't really checked direct mode out
thanks
thanks
Post edited by chemical on
I usually listen to my 2 ch. music in Pure Audio Mode, I just think it sounds better .....
thanks....and i agree -
i use the pure direct on my yamaha
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
I go back and forth between pure direct and stereo on my Yami, but for hard rock I will sometimes use two channel enhancedThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
2ch enhanced add's some "oomph" but i can do without
I would really like to get a better cart/stylus soon....Media Room 7.1
HTPC
I like my Shure 97xe cartridge.
I'm not impressed by the photo-pre capabilities of the onkyo though recievers though. I listen to LPs and CDs in Direct mode on my Onkyo 777, but I'm considering a seperate Pre because I'm not happy with it.~Matt
My System
Front L/R: Definitive BP10Bs
Surrounds -Polk Audio Monitor 4As
Preamp: B&K Reference 20
CD: Jolida JD100a
L/R Amp: Carver TFM-24
Turntable: Pioneer PL-516 W/ Shure M97xe
TV: Sony 52" XBR9 -
sTiLlLeArNiNg wrote: »2ch enhanced add's some "oomph" but i can do without
It sounds quite good with Def Leppard and other metal bands... otherwise I do not use it.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
That's also what i'd like to get, i have heard of them being reffered to as "baby v15's" by some....Media Room 7.1
HTPC
Sadly I haven't heard v15, but for $80 shipped from amazon, you can't beat the M97xe.... It sounds miles better than the Audio Technica cart that was on my t/t when I bought it.~Matt
My System
CD: Jolida JD100a
TV: Sony 52" XBR9 -
you're absolutely right! I have been told that Dual/Shure combo is hard to beat for the money
For now i have one half of the equation
Media Room 7.1
HTPC
