new t/t
chemical
chemical Posts: 100
edited September 2009 in 2 Channel Audio
i recently purchased a new t/t.....and i am getting back into my old lp's
i know its what my ears hear,but i was just wanting some opinions on what mode to listen to the lp's in.
i have an onkyo 806 and have been using the pure audio mode
is there much difference in the direct mode,i haven't really checked direct mode out
thanks
Post edited by chemical on
  • jimmydep
    jimmydep Posts: 1,305
    I usually listen to my 2 ch. music in Pure Audio Mode, I just think it sounds better .....
  • chemical
    chemical Posts: 100
    jimmydep wrote: »
    thanks....and i agree
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    i use the pure direct on my yamaha :o
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
    nooshinjohn Posts: 26,105
    I go back and forth between pure direct and stereo on my Yami, but for hard rock I will sometimes use two channel enhanced
  • sTiLlLeArNiNg
    2ch enhanced add's some "oomph" but i can do without :o
    I would really like to get a better cart/stylus soon....
    Media Room 7.1
    HTPC
  • Paden501
    Paden501 Posts: 286
    I like my Shure 97xe cartridge.
    I'm not impressed by the photo-pre capabilities of the onkyo though recievers though. I listen to LPs and CDs in Direct mode on my Onkyo 777, but I'm considering a seperate Pre because I'm not happy with it.
    ~Matt
    My System
    Front L/R: Definitive BP10Bs
    Surrounds -Polk Audio Monitor 4As
    Preamp: B&K Reference 20
    CD: Jolida JD100a
    L/R Amp: Carver TFM-24
    Turntable: Pioneer PL-516 W/ Shure M97xe
    TV: Sony 52" XBR9
    It sounds quite good with Def Leppard and other metal bands... otherwise I do not use it.
  • sTiLlLeArNiNg
    Paden501 wrote: »
    That's also what i'd like to get, i have heard of them being reffered to as "baby v15's" by some....
    Media Room 7.1
    HTPC
  • Paden501
    Paden501 Posts: 286
    Sadly I haven't heard v15, but for $80 shipped from amazon, you can't beat the M97xe.... It sounds miles better than the Audio Technica cart that was on my t/t when I bought it.
    ~Matt
    My System
    CD: Jolida JD100a
    TV: Sony 52" XBR9
  • sTiLlLeArNiNg
    you're absolutely right! I have been told that Dual/Shure combo is hard to beat for the money ;) For now i have one half of the equation :(
    Media Room 7.1
    HTPC
