Adcom 535L in Chicago CL $90
kawizx9r
I checked these out on audiogon and ebay and the average price is higher than what he's asking so thought I'd post this up.
No affil - http://chicago.craigslist.org/wcl/ele/1375736044.html
Might just grab it, even though I don't need it.
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Polk SR104
Any clue how to use the internet? Found it in about 10 sec.
Post edited by kawizx9r on
Not trying to steal your thunder Freddy, but i decided not to pursue this amp and would pass it along since we're talking about 535s...
http://indianapolis.craigslist.org/ele/1373016004.html
GFA-535 for $50. I'm going up to pick up some 11TLs and possibly a GTP-500 from this guy this evening, so i can take a look at it for anyone.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Not trying to steal your thunder Freddy, but i decided not to pursue this amp and would pass it along since we're talking about 535s...
Geez that's even better! Grab both for $140 (or maybe less for the one in my area) and you can bridge these babies up for some pretty sweet sound
Too bad I can't edit the title of this thread :rolleyes:Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Wait... these are bridgeable? You wouldn't happen to know the output when bridged, would you?
I'm trying to get some real power behind my speakers just as a cheap (hopefully) experiment to see if my 150wpc oinker is choking anything.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Edit: Nevermind guess not, I'm probably thinking about the 555. My mistake, although these things support a 4ohm load.
Specifications
* Power output, watts/channel, continuous, 20 Hz - 20 kHz, <0.04%THD: 60 watts at 8 ohms 100 watts at 4 ohms
* Signal-to-noise ratio, A-weighted, 60 watts into 8 ohms: >110 dB
* Input impedance: 100,000 ohms
* Input sensitivity: 60 watts into 8 ohms: 0.97 V rms 1 watt into 8 ohms: 130 mV rms
* Damping factor (20 Hz - 20 kHz): >180
* Dynamic headroom into 4 ohms: 3.0 dB
* Chassis dimensions: 3" (76mm) x 17" (432mm) x 11 1/4" (286mm)
* Maximum dimensions: 3 3/8" (86mm) x 17" (432mm) x 12 1/2" (317mm)
* Shipping weight: 23 lbs. (10 1/2 kg)Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Iirc I thought you could, let me double check that though. Maybe someone can come in here and tell us what each amp puts out if bridged.
I wish my Oinker was bridgeable. I love the way it sounds, and i can pick another one up for peanuts.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Specifications
Hrmmm.... kindof glad i didn't pick it up then.... I never bothered to look up the specs when i had mine, but i wasn't really a fan. Always thought there might have been something wrong with it, but not worth it for me to try another one i guess. Bummer.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
