Adcom 535L in Chicago CL $90
kawizx9r
kawizx9r Posts: 5,150
edited September 2009 in Electronics
I checked these out on audiogon and ebay and the average price is higher than what he's asking so thought I'd post this up.
No affil - http://chicago.craigslist.org/wcl/ele/1375736044.html
Might just grab it, even though I don't need it.
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104
heiney9 wrote: »
Any clue how to use the internet? Found it in about 10 sec.
Post edited by kawizx9r on
  • concealer404
    concealer404 Posts: 7,440
    Not trying to steal your thunder Freddy, but i decided not to pursue this amp and would pass it along since we're talking about 535s...
    http://indianapolis.craigslist.org/ele/1373016004.html
    GFA-535 for $50. I'm going up to pick up some 11TLs and possibly a GTP-500 from this guy this evening, so i can take a look at it for anyone.
  • kawizx9r
    Geez that's even better! Grab both for $140 (or maybe less for the one in my area) and you can bridge these babies up for some pretty sweet sound :D
    Too bad I can't edit the title of this thread :rolleyes:
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • concealer404
    Wait... these are bridgeable? You wouldn't happen to know the output when bridged, would you?
    I'm trying to get some real power behind my speakers just as a cheap (hopefully) experiment to see if my 150wpc oinker is choking anything.
  • kawizx9r
    Edit: Nevermind guess not, I'm probably thinking about the 555. My mistake, although these things support a 4ohm load.
    Specifications
    * Power output, watts/channel, continuous, 20 Hz - 20 kHz, <0.04%THD: 60 watts at 8 ohms 100 watts at 4 ohms
    * Signal-to-noise ratio, A-weighted, 60 watts into 8 ohms: >110 dB
    * Input impedance: 100,000 ohms
    * Input sensitivity: 60 watts into 8 ohms: 0.97 V rms 1 watt into 8 ohms: 130 mV rms
    * Damping factor (20 Hz - 20 kHz): >180
    * Dynamic headroom into 4 ohms: 3.0 dB
    * Chassis dimensions: 3" (76mm) x 17" (432mm) x 11 1/4" (286mm)
    * Maximum dimensions: 3 3/8" (86mm) x 17" (432mm) x 12 1/2" (317mm)
    * Shipping weight: 23 lbs. (10 1/2 kg)
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • concealer404
    kawizx9r wrote: »
    Iirc I thought you could, let me double check that though. Maybe someone can come in here and tell us what each amp puts out if bridged.
    I wish my Oinker was bridgeable. I love the way it sounds, and i can pick another one up for peanuts.
  • concealer404
    kawizx9r wrote: »
    Specifications
    Hrmmm.... kindof glad i didn't pick it up then.... I never bothered to look up the specs when i had mine, but i wasn't really a fan. Always thought there might have been something wrong with it, but not worth it for me to try another one i guess. Bummer.
