My first DIY subwoofer
kawizx9r
kawizx9r Posts: 5,150
edited August 2010 in DIY, Mods & Tweaks
Title says it, it's my first DIY subwoofer. I've made maybe 2 boxes total in the past for car audio, but nothing crazy at all. This project is posted on another forum as well but it seems that place doesn't get much traffic and the only person helping there is a mod (thanks Mike).
So far it's come out to 209 bucks for the amp+sub driver (shipped) and materials. I'll need a few more such as the porting, stuffing, etc. Talk about a budget subwoofer though :D
Mike used some software to determine the length of the port using a 4" flared port to reach output of around 19-21hz. He suggested I go with a total length of 17" for the box that is approximately 4 cu. ft. Question is, what is/should be the diameter of the actual port inside the box? Can I get away with 2" since that's what it seems that the original HSU VTF-3 HO subwoofer uses anyway. I assumed the 4" diameter was of the flared port itself, especially after going to Lowes today and seeing how big a 4" pvc pipe really is. :rolleyes: Pics to come
-Freddy
PS Do I count the sub driver as part of the cost? My wife bought that for me :D
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104
heiney9 wrote: »
Any clue how to use the internet? Found it in about 10 sec.
Post edited by kawizx9r on
«1345
  • kawizx9r
    edited September 2009
    Here's the driver, don't mind the dust....I had just taken it out of the triple box packaging and it got a tad bit dirty.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • leroyjr1
    leroyjr1 Posts: 8,785
    Call Epik, SVS or HSU to see if they have any ports for sale
  • kawizx9r
    Dayton plate amplifier, MDF board and a few other things
    I've still got a sheet of 2' 4 1/2" x 4' 1/2" of mdf and 3 panels, since I'll have plenty left over I might just karma it or give it away to anyone that might need/use it around here.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • leroyjr1
    What's the power rating of the amp plate?
  • ben62670
    ben62670 Posts: 15,969
    The port is actually 4 inches id from one end to the other. A 2 inch port would be chuffing from too much port velocity.
    Ben
  • kawizx9r
    leroyjr1 wrote: »
    It's a Dayton 240watt@4ohm rms amplifier as a friend said, but this thing has a much larger transformer and requires a bit more power than P.E.'s current 240watt Dayton amp. The driver sounded very nice when tested on free-air :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    ben62670 wrote: »
    Hmm...here's a link of the HSU VTF-3 MK3's insides. It uses the same everything to include box size except a different driver and slightly less rated amplifier. http://www.audioholics.com/reviews/speakers/subwoofers/vtf-3-mk3-sub/vtf-3-mk3-build-quality
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • leroyjr1
    Are you going to do any bracing to the box?
  • kawizx9r
    leroyjr1 wrote: »
    Yep, I can get away with plywood as it's stated on alot of other DIY projects but since I've got plenty of MDF left over I'll use that. I do know that'll take into account the actual volume of the box as well and will probably keep it near factory-spec.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • leroyjr1
    Check out some pics from AVS Forum DIY subwoofer threads.
    http://www.avsforum.com/avs-vb/showthread.php?t=646455
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Looks like a fun project Freddy!
    I've thought about going the DIY route myself, when I decide to upgrade my sub. The Epik Vanquish(or maybe the Sentinel) is screaming my name though...:cool:
    That upgrades still up in the air though.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • kawizx9r
    leroyjr1 wrote: »
    Nice, I've done a hell of alot of picture hunting and have seen some great builds. Here's a few on this site, scroll down and check out the Rubik's cube ;)
    http://www.rythmikaudio.com/reviews.html
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    I've thought about going the DIY route myself, when I decide to upgrade my sub. The Epik Sentinel(or maybe the Vanquish) is screaming my name though...:cool:
    Heh, I could still wait awhile and grab something bigger and badder down the road but this DIY subwoofer just has the 'fun factor' in it :D That and my place is pretty small, so this sub alone will be overkill.
    Those Epik's are beasts! You can check them out personally near Crystal Lake just an hour from me. Thing is if you walked in there, you'd be sure to walk out holding one of those badboys lol
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • ben62670
    DIY subs are a great way to fly if you can build a good box. There are a few of us hear that have built some subs that cost $400-700 to build that smoke many other subs that cost much more.
    Do you have one of these and a router?
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=365-250
    Best money you will ever spend building your own speakers
    Ben
  • jacob.simpson
    jacob.simpson Posts: 481
    Can you provide the link to the web where you bought the amp since i am looking for one with dual voltage selector, this would probably for a diy project/
  • kawizx9r
    ben62670 wrote: »
    I've seen those and heard many great things. No unfortunately I don't have the tools at my disposal. I might have to do the work at my wife's uncles house tbh, we'll see. Unless a local polkie wants to help me out some? :p
    Any thoughts on the port after looking at the link on audioholics Ben?
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • comfortablycurt
    kawizx9r wrote: »
    That's part of the reason I want to buy an Epik. They're designed, and BUILT in the United States...plus they're even in my home state. I try to buy as much American stuff as I can...that's hard to do anymore though...
    I may still end up doing a DIY sub...that's all yet to be determined. My current sub is more than enough for my small room, so I'm not too worried about it yet.
    At this point though, I'm guessing I'll end up eventually going with a pair of Epik Vanquish's. I want a nice, tight, fast, sealed musical sub, that can also hit nice and low for HT...a pair of them actually. The Vanquish should fit the bill.
    My system get's used for music far more than HT...probably like an 80/20 split, so I value musicality over anything else. Stereo subs would be great.:)
  • kawizx9r
    It's the model prior to this one - http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-804
    I got it from a friend that didn't even need it or use it for much cheaper. Looking at the one on Parts express though I don't see a voltage select switch. I could recommend checking out oaudio.com as well for a plateamp, see if they've got any with different voltage settings. I've read alot of good things about them as well and considered them if I didn't go with the Dayton amp.
    You can always modify one too to run @240v I would think, but you'd have to turn elsewhere for that sort of thing.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kcoc321
    kcoc321 Posts: 1,788
    http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=505
  • jacob.simpson
    Tnx for the update, yes the PE no more has any with dual voltage,
    i have not heard much reviews about oaudio, they do have a dual voltage amp. I myself was planning svs to use here and take home when i go back, but the transport cost to my country is unimaginable and very high.
    Other option what i have is MPDSW1000
  • kcoc321
    maybe try the Dalton website direct.
    Or give PartsExpress a call.
    I have read good things about their CS.
  • kawizx9r
    You guys should've seen the face though on the guy that cut the MDF at Lowes, along with the expression my wife gave shortly after.
    The first 2 panels cut were the 20" x 17", and he asked if those were the sides.....I told him that's just the front/rear.
    When he asked what the next 2 pieces were, I said 23 1/2" x 20" once they were cut out they only imagined how big the box would actually be :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • jacob.simpson
    kcoc321 wrote: »
    yes i did check pe cs but they dont carry any dual volt now.
    will try Dayton web
  • ben62670
    You do not want to use a 2 inch port on a driver 10 or more inches. Did you use WINisd to model the speaker design?
    Ben
  • kawizx9r
    ben62670 wrote: »
    Not the port itself, I meant the tube inside. Maybe it looks to be 3 inches wide, I'm not sure.
    The guy used WINisd to determine the length needed and such utilizing a 4" flared port. Also told me I'd see a maximum cone excursion of 19 mm at 14.5 hz. The plateamp's got subsonic filtering and won't even see anything below 18hz if it was able to reach it. Did you check out that site I linked showing the inside of the VTF-3 MK3? Just want to get it all right :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    I'll think about doing what Lee said and call HSU tomorrow, though I want said-materials at hand already so I can work on how I will brace this thing I.E. have correct dimensions/etc. Ordering something would add a few more $ and would put off this project even longer.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • ben62670
    Again the 4 inch measurement is the id of the tube from the front to the rear. The ends will flare out anywhere from 5-8 inches.
    Ben
  • kawizx9r
    ben62670 wrote: »
    Seriously? :eek:
    The model sold uses two of these things, after seeing one today I didn't want to imagine how I'd work that thing in there. Ok, guess I'll stick with the 4" ID tube :D should be fun.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • messiah
    messiah Posts: 1,790
    You should have grabbed the amp I directed you to. Too late I guess Freddy.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • kawizx9r
    messiah wrote: »
    Sorry Christopher! I know which ones you're talking about. If I wasn't going to see a warranty or something, I figured I'd save some more and go used. Thing is this amp is in near-new condition and was pretty cheap :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
