DefTech BP10B as DJ speakers?
Serendipity
Some of you may know this -
I run the PA at my church and for many years, used an Adcom GFA-535 to power a pair of 15" JBL monitors along with two 12" Ramsa cabinets.
I want to use the DefTechs as a pair of monitors being driven by a Peavey powered mixer or Crest Audio CA4:
Would this work for the application? Attached is a picture of the rig.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
i wouldn't do it you're gonna blow those speakers!Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I would not do that either. The Def Techs are very good speakers but more for referance and not for concert level audio listening.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
thuffman03 wrote: »I would not do that either. The Def Techs are very good speakers but more for referance and not for concert level audio listening.
This is not going to be for excessively loud levels, BTW.polkaudio RT35 Bookshelves
The BP10b's I have are designed to reflect off the back wall. I don't think they would do much out in the open. You would be better off with a full range monitor.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Polkersince85 wrote: »The BP10b's I have are designed to reflect off the back wall. I don't think they would do much out in the open. You would be better off with a full range monitor.
Thanks. Looks like I'll have to use something else.
Anybody here have experience with the Mackie SRM450v2 vs. JBL EON G2?polkaudio RT35 Bookshelves
