DefTech BP10B as DJ speakers?
Serendipity
Serendipity Posts: 6,975
edited September 2009 in The Clubhouse
Some of you may know this -
I run the PA at my church and for many years, used an Adcom GFA-535 to power a pair of 15" JBL monitors along with two 12" Ramsa cabinets.
I want to use the DefTechs as a pair of monitors being driven by a Peavey powered mixer or Crest Audio CA4:
Would this work for the application? Attached is a picture of the rig.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • nguyendot
    nguyendot Posts: 3,594
    i wouldn't do it you're gonna blow those speakers!
    Main Surround -
  • thuffman03
    thuffman03 Posts: 1,325
    I would not do that either. The Def Techs are very good speakers but more for referance and not for concert level audio listening.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Serendipity
    thuffman03 wrote: »
    This is not going to be for excessively loud levels, BTW.
  • Polkersince85
    Polkersince85 Posts: 2,883
    The BP10b's I have are designed to reflect off the back wall. I don't think they would do much out in the open. You would be better off with a full range monitor.
  • Serendipity
    Thanks. Looks like I'll have to use something else.
    Anybody here have experience with the Mackie SRM450v2 vs. JBL EON G2?
