Is 65W enough for RTi A5s or Monitor 60s?
christo4
Hey! I have a Yamaha 2-channel receiver rated at 65W, though I feel it has more power than my old JVC 100W amp. Anyway, I currently use it for a pair of RTi 4s (smallest bookshelf in that line), and love the sound. I am thinking about upgrading to a pair of floor-standers and am considering either RTi A5s or Monitor 60s. What do you guys think? Do I have enough power for these? I listen mainly to music at low (intimate) volume levels. Thanks for your advice!
Post edited by christo4 on
You'll be fine. Both the RTi's and the Monitors are pretty efficient, and real easy to drive.
They would definitely benefit from more power, but you'll be fine powering them with 65 watts as long as you're careful with the volume knob. Don't turn it up too high.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »You'll be fine. Both the RTi's and the Monitors are pretty efficient, and real easy to drive.
Agreed, 65w will do the job for now.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Granted, this calculator does not take into account and "actual experiences, but technically using the "Amp power required" calculator that someone posted on another thread...
input distance: 4m
speaker eff: 90dB
amp head room: 3dB (min recommended) headroom to keep the amplifier(s) out of clip.
req'd dB: 93.1dB (max listening)
= 65w amp
calculator link:
http://www.crownaudio.com/apps_htm/designtools/elect-pwr-req.htm
Hope that helps
It will do the job for sure but, it won't hold a candle to a separate power amp.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
You have received some good advice. I had an H/K 645 (75W) driving my RTi8s and they sounded very good. However, when I upgraded to a Sunfire TGR-3 (200W), the sound went to a different level. Enjoy the audio upgrade trek.7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi -
the Yammy will do but if it has preouts try to find an external amp, it can make a world of difference. For a while I listend to my rti8 with my H/K avr254 and it did a decent job. Then I hooked up a parasound hca2205at amp and it was the last time I will ever go w/o an external amp.
____________________
Polk Lsi9's Front and Rear
Polk lsic center
hk avr254 -
Yes.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
