What racks are you guys using? VTI any good?
TouchOfEvil
TouchOfEvil Posts: 967
I am looking for a new rack, been using a target all wood cheap 100.00 rack for a little while now and want something a little better.
I was looking at these two as both would suit my needs. Tell me what you think or maybe you can suggest something different.
http://www.racksandstands.com/asp/show_detail.asp?sku=VI1020&PiID=1185
or this one?
http://www.tvstands.com/VTI-BLG404BB-VI1127.html
Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
Post edited by TouchOfEvil on
  • FittyFieFo
    FittyFieFo Posts: 482
    edited September 2009
    I was seriously in the same position as you right now. Do you have a TV Stand and do you like matching your furniture?
    I prefer the 2nd link. This is what I got. (This store is in IL only)
    http://www.abt.com/product/35060/OmniMount-G303DARK.html -- Audio Rack
    http://www.abt.com/product/24521/Bell-O-PVS4218HG.html -- TV Stand.
    Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
    Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
  • Ern Dog
    Ern Dog Posts: 2,237
    I've got the Vti BLG404 and love it. I haven't had any problems with the unit.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    I am not too impress with these new type racks but the BL404 series seems to have a little bit more style than the BLG404 series (looks too commercial for my taste).
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • TouchOfEvil
    FittyFieFo wrote: »
    No tv stand i am planning to wall mount it. I'm moving my stuff into a bigger room and want just a rack to center under the tv/center channel.
    Gonna have the tv fairly high then wall mount the center under that. Then have the audio rack.
    I wanna give the speakers as much room to breath on the sides as i can.
    But don't want to place the center on the rack because of the vibrations.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • TouchOfEvil
    TECHNOKID wrote: »
    Cheers!
    TK
    Sweet thanks for your input. The BL404 is cheaper by a nice amount and does look better.:)
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • Conradicles
    Conradicles Posts: 6,339
    BL404 gets my vote too, need to start saving my pennies, I like that one a lot.
  • messiah
    messiah Posts: 1,790
    I cant comment on the rack, but my VTI stands are very well built IMO. Almost as nice as my Sanus, but cost much less.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • TouchOfEvil
    messiah wrote: »
    Cool, i think i am going to get the bl404 the price seems right to me and i like the cherry finish option.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • mmadden28
    mmadden28 Posts: 4,283
    I'm using the Salamander Synergy S40 in my 2 channel rig. You can customize it with and without sides, a back or a door or change the door to a frosted glass one. You can add casters, drawers, etc. The shelves are infinitely adjustable and hold a good amount of weight. Oh yeah, and you can get them in varying heights and widths
    Stock pic:
    ____________________
    Pool: Atrium 60's/45's
  • TECHNOKID
    mmadden28 wrote: »
    Stock pic:
    I like the looks, would be nice if a rack mount style was available, is it?
    DARE TO SOAR:
  • debussyj
    debussyj Posts: 198
    I have a Studiotech U-48 with casters for my HT setup and I really love it. The casters make it easy to move and the removable panels in the back make cord management a snap. It also fits large electronics, which I always seem to end up with. Granted, it's not cheap, but I think it's sturdy, well built and the wood finish is nice.
  • mmadden28
    mmadden28 wrote: »
    Stock pic:
    TECHNOKID wrote: »
    Not sure-I've just been putting my gear on the shelves. It doesn't have any mount points for rack mount screws-but it will fit rack mountable products--its got the clearance (as should any respectable rack).
    I also bought a Middle Atlantic Rack frame for the purpose of rack mounting some equip. At the time I wasn't sure what I would use it for. If I decided to use it for my 2 ch rig, I was going to craft some side panels and trim frmo some nice hardwood. But I also bought the Salamander so I decided to use the MA Rack it in my 2nd Home Theater and will recess it into the wall.
    They may have other models that may work for mounting.
    I like the Salamander Archetype series as well. More open (note the Synergy Series above can also be open).
    I've considered building my own from scratch in this style.
  • bklynNupe
    bklynNupe Posts: 728
    I wanted the Salamander S40 but got a sweet local deal for a new VTI off Audiogon
    http://www.hometheaterplus.com/vti-hgr406.html
    Nice looks really substantial, very thick glass and sturdy.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
  • lightman1
    lightman1 Posts: 10,796
    I like well built, natural racks. Something about the look and feel of them. Especially the ones with delicate curves and plenty of support.
  • TouchOfEvil
    lightman1 wrote: »
    I concur.:D
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • lightman1
    I concur.:D
