Monoprice or Blue Jeans Cable
  • lightman1
    lightman1 Posts: 10,797
    edited September 2009
    Viper...some companies reduce the diameter of the connects to get better metal to metal contact. Thus reducing the chance of an air gap between the IC and input. Deoxit does have its advantages though.
  • ViperZ
    ViperZ Posts: 2,046
    lightman1 wrote: »
    lightman, reducing the diameter has to be reasonable (I am sure it's within some spec or whatever), but making is too tight is never good. IMHO, monoprice premium connectors are too tight.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • BlueFox
    BlueFox Posts: 15,250
    ViperZ wrote: »
    The tighter the better, so long as the connection can be made. A tighter connection insures a better electrical connection. Additionally, there is less chance of inadvertently dislodging the connection.
  • ViperZ
    ViperZ Posts: 2,046
    BlueFox wrote: »
    There is a big difference between tight and very tight. If the connector is too tight, you are running a very good chance of breaking a solder connectoin between the connector and the board when you'll be connectnig that 'nice and tight' cable.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    F1nut Posts: 52,005
    If it's so tight that it's a struggle to put it on or take it off, well that's just a bad design. For the best connection, locking RCA's like the kind MIT uses are the best by far.
