Speaker Calibration w/ S&V Disc
kberg
kberg Posts: 974
edited September 2003 in Speakers
Can anyone confirm whether calibration using the S&V disc requires 75 dB or 85 dB test tones, or if it really matters? I thought it was 75, but thought I saw a much earlier thread stating 85.
I believe the disk states anything over 70, but I'm not sure.
Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688
Post edited by kberg on
  • faster100
    faster100 Posts: 6,124
    I think its 85 db, doesnt the disk say?
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • jgido759
    jgido759 Posts: 572
    I received this response to an e-mail I sent to Ovation Software (the makers of S&Vs Tune-Up disc):
    "The tones on S&V are just like Avia. Now, if you set with our tones
    using Avia and 85 and then play back Video Essentials at 75, they should be the same. VE encodes the tones at -10 dB, we encode at 0 dB. This is why we are 85 dB and VE is 75 dB.
    S&V also contains DTS test tones.
    If you compare DD to DTS, DTS will be 4dB louder. This is because our disc is encoded -4dB on DD. This is called Dialog Normalization and it is set to -27. (-31 is 0 offset.) This is done because the majority of DVD movies are also encoded at -27."
    Hope this helps.
    Oh, you hate your job? Why didn't you say so? There's a support
    group for that. It's called EVERYBODY, and they meet at the bar.
    -Drew Carey
    There is a very fine line between "hobby" and "mental illness."
    -Unknown
    My DVD Collection
  • kberg
    kberg Posts: 974
    Thanks jgido,
    I calibrate to DTS 6.1 on the S&V disk, but it'd be a pretty neat feature on an AVR to be able to calibrate for both DD and DTS, and then just switch between the two (instead of either recalibrating or writing down and changing the numbers for one or the other) when needed.
    Sub: SVS 20-39 PC+
  • kberg
    kberg Posts: 974
    Just saw another post by Doc on using 85 dB for the S&V disc to calibrate for Reference Level purposes.
    Sub: SVS 20-39 PC+
  • kingtut
    kingtut Posts: 813
    I just received the S&V disc. The instruction on the S&V DVD itself said to calibrate it at 70dB. That's what I did. The disc must be giving erroneous info.
  • kberg
    kberg Posts: 974
    I thought there was conflicting info, hence my question. I calibrated to 85 dB, anyway. Thanks for checking!
    Sub: SVS 20-39 PC+
