Mini-review...Aric 3.7 Tube Preamp
starkiller
starkiller Posts: 2,723
edited September 2009 in Electronics
Well, I have had this for about 6 weeks so time for a short review I guess :) After the initial burn-in and listening, I did some tube rolling. The unit came with Baldwin 12AU7 tubes. I have settled on some Mullard 12AT7 4024's and they really helped the sound get focused, smooth but precise. Mated with a Rotel 930bx amp, Rega Planet CD player and Yamaha NS-100M speakers the garage has never sounded so good :D
With a customized price of only $335 the unit is a steal! Aric changed one of the inputs to a second output so i could use it in the future for a sub if i wish. Ferrari Red and two nice glowing tubes...tis wonderful.
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
    F1nut Posts: 51,760
    We need pics. :)
  • starkiller
    okey-doke, pics when i get back home :)
  • comfortablycurt
    comfortablycurt Posts: 6,745
    We need pics. :)
    +1
    Congrats on the toy Alan. Good to hear you're happy with it!
    Was this the replacement for the Acurus L10 that I bought?
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • starkiller
    curt
    no, the replacement for the acurus was the valve audio black widow hybrid preamp...the aric and rotel replaced the nad 3130 :)
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    waiting on the pics as well, an **** end as well please. not familiar with this piece so looking forward to your thoughts, always on the look out for quality entry tube pieces to help folks ease the washing of the sand from ears to their toes.
    RT1--Tubes Rule
  • marvda1
    marvda1 Posts: 4,943
    Puritan PSM156
    heiney9 Posts: 25,432
    I have almost pulled the trigger twice on one of his units. There was one local on e-bay awhile back and I just didn;t know enough about it. Looking back, local pick up and less than $200........I should have just bought it.
    So you are using 12AT7's and they seem to work fine? I have a Dared Sl2000A I bought instead of the Aric and it takes 12AT7's and variants of which I know have several. It would be nice to use the same tubes I use in the Dared.
    Have you tried any of the other variants:
    I have used 6414, E180CC, 5965, 6201, 6211, 6679, 7728, ECC81 in place of a 12AT7. Some are equivalents to the 12AU7. It would be an interesting piece to pick up. It seems so far the Dared is staying in my main rig.....................tubes are nice!
    RT1--Tubes Rule
    Add the Dared Sl2000A to this list.
    WOW, I am loving mine and I think it compares to the Dodd ELP if running the right tubes.
  • Face
    Face Posts: 14,340
    Does it use a wall wart power supply?
    Face wrote: »
    Yes, it does...............that was one of my main concerns about getting one. I forgot about that. Good point.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    heiney9 wrote: »
    I had fun with that pre for a bit. I'm actually on the lookout for another one for the near future.
    If I can pry the Dared out of the main rig I'd love to use it in the office rig with a single Monarchy SM70.
    I am running the Dared thru the HT bypass of the Adcom GFP-750 so I can use either pre-amp and I have to say so far the Dared is holding it's own against the 750 and with the right tubes it sounds slightly better on some recordings (as only tubes can). Mine has the Auricaps for coupling caps as well as nice Nichicon bypass caps and Allen Brady resistors. I've been extremely impressed with the little gem.
  • zombie boy 2000
    heiney9 wrote: »
    I used that exact same combo with some Totem Arros and I still consider that the best sounding set up I have ever owned. I WILL put that system back together some day.
    Having a hard time finding a single SM70. There is a guy on Audiogon willing to sell a single. So we'll see.
  • zombie boy 2000
    I've never heard the SM70 (as I had the SM70 Pro), but I can't imagine much of a difference.
    Starkiller - I took a looksie at their site. Looks like some fun and good sound on a budget.
  • starkiller
    i will get those pics, i will i will i will :) been dealing with my bro' on our father's estate..no fun i tell ya, especially when we are so different from each other in many many ways.
    yeah, check out his website..pretty cool stuff. he told me he might get into amplifiers also. apparently an audio mag is reviewing the 3.6 preamplifier also!
  • danz1906
    danz1906 Posts: 5,144
    Congrats!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • starkiller
    pics are lousy, i think my camera batteries are going :(
